Big Boost?
Old Apr 20, 2006 | 10:26 PM
LightningToGo's Avatar
Big Boost?
Who is running 20 or more either with a KB or Whipple on a daily driver? Is there a issue with stock gaskets running at these levels?
Old Apr 21, 2006 | 06:45 AM
No one running big boost?
Old Apr 21, 2006 | 04:20 PM
BigSVT's Avatar
bump
Old Apr 21, 2006 | 04:27 PM
St Louis Lightning's Avatar
I drive mine around on my 20psi setup all the time. In normal around town driving, I'm only hitting 5psi or so pulling from a stop.. There is no reason a 20psi truck can't be driven every day.
-Mark
Old Apr 22, 2006 | 12:40 AM
SILVERLIGHTNING's Avatar
I have been at 20 PSI for about 2 years now.
Gaskets are 6 years old.
FF
Old Apr 22, 2006 | 01:26 PM
Rob_02Lightning's Avatar
FF
So is that Stock Block
But it is still faster than mine
LTG
I was running up to 25lbs through my mag, unfortunately a valve broke a few
thousand miles later so I never got long term results, however Jim did tell me I was already losing a head gasket when the motor was taking apart.
(The Boost +150 HP of Nitrous may have played in my failure though)
ONE THING YOU MUST REMEMBER
You must get it OUT OF THE HEADS AND EXHAUST. Thats where I totally screwed up on motor #1. Now I have oversized Valves, a differant angle on the Valve Ports, their ported large enough to pass a small farm animal through, and with the same pulley combo I see a lot less boost.
What heads are you using, and exactly what Pulley combo do you have in mind ???
Old Apr 22, 2006 | 02:57 PM
LatemodelRacer2's Avatar
I run a 10" lower with a 2.8 upper on my KB on a semi DD basis. I really have found running the 2.8 upper is almost pointless on the street so i end with the 3.25 upper. But to answer your Q 3k miles on my truck at 18lbs and sometimes even a 50 shot with no problems yet except a slight tranny leak but thats irevelant to boost more to the power.
Old Apr 22, 2006 | 04:44 PM
Rob,
You got to have the Slowest"Built Block" Lightning in the world!
When are you going to run that thing?
FF
Old Apr 23, 2006 | 10:11 PM
LTG
8lb lower and a 3.0 on upper.
