Clay Bar lube
Old Apr 19, 2006 | 10:52 PM
stokdgs's Avatar
Originally Posted by stokdgs
I use the claybar to remove the things that stick to the paint that I can feel after I wash and dry it and then run a clean dry hand over it. Zaino says that their claybar will remove contanimants and may remove some of their product. I find this to be true. Their polishes do not contain any abrasives in them at all. They also say as a rule to not Dawn wash the paint except for the first time before using their product. Im trying to get lots of layers of Zaino Z-5 and Z-2 Pro on all my vehicles, and can definitely see and feel a difference after the last 6 coats I did. Its really shiny with just 1 coat but the more you use the better it gets. I use the claybar about 2 times a year and follow afterward with Z-6 spray, and Z-5 on the dark colors and Z-2 on the lighter. I just did the Lightning, poured out 1/2 oz of Z-5 with 3 drops of ZFX catylyst, and had more than enough to do 3 coats on the Lightning and 2 coats on the wheels, could have done another coat on the wheels, but I got tired. For a claybar spray, Zaino says to use a few drops of their carwash and water, but any Detail Spray works fine. The lube in Claymagic works good, but I prefer to use Meguiars Spray Detailer. Plain water is not slippery enough to me. A magazine tested all the waxes, polishes, etc., out there and found that Zaino lasted longest. Hope this helps. DanF
Sorry, forgot to say that I used to use the Porter Cable 7424 to do all this but found that its a big waste of product, unless you are rubbing out the finish with a swirl mark remover, etc.. I did all of this work using the cotton applicator pad you can get from Zaino by hand, remember, its no hard rubbing needed after you get the paint clean and clear with the claybar and if you need additional mark removal. (Zaino makes an excellent product for mark removal, called Z-PC Fusion that I would use with the machine and a foam pad) DanF
Old Apr 20, 2006 | 11:30 AM
Mook's Avatar
Just use some carwash soap diluted with water. That will be all you need.
Mook
