AMW Catch Can
Old Apr 20, 2006 | 08:09 AM
Dbl G's Avatar
I have been running mine for over a year and it works perfectly...The Mesh is Stainless Steel wool
Old Apr 20, 2006 | 08:14 AM
Daves00L's Avatar
Just bought one of these to replace the home depot setup. awesome machine work. this just goes inline to replace this, correct ? i assume the setup is the same - PCV valve->hose to catch can->hose to upper plenum right at IAC valve, etc.
are you running a check valve like instructions say, to prevent overpressure from intake going back into can ? personally, don't think it's necessary
any info would be appreciated
thanks
Dave
2001L
Old Apr 20, 2006 | 02:23 PM
rheagrimm's Avatar
thanks
Dave
2001L
I too have been trying to find out if anyone is using a check valve and if so what type.
Old Apr 20, 2006 | 02:29 PM
TampaBlack99's Avatar
Tampa - The AMW is packed with about 2 inches of steal wool mesh. It is doing a fantastic job of stopping the oil laden air from getting into the plenum.
Then it probably works great. Mine has around 6 heavyduty steel pads inside.
Old Apr 20, 2006 | 02:33 PM
rheagrimm's Avatar
Originally Posted by Dbl G
Do you have any pictures of the bracket with the AMW catch can attached to it? Also what is the mounting bracket made out of?
Old Apr 20, 2006 | 03:35 PM
Whatever you do don't use the crap plastic hose that comes with most catch cans. I found a steel spiral reinforced hose that works great.
Old Apr 20, 2006 | 03:45 PM
TrackBeast's Avatar
Man! That's a real killer catch can. It probably could withstand a direct hit nuclear strike. Nice.
TB
Old Apr 20, 2006 | 09:45 PM
Dbl G's Avatar
Aluminum
Old Apr 20, 2006 | 10:06 PM
TrackBeast's Avatar
Holy mackerel my eyes hurt.
Dbl G, Could you warn us next time.
Actually works really well on a Harley.
TB
Old Apr 21, 2006 | 01:07 AM
rheagrimm's Avatar
Thanks Dbl G! Very nice work.
