Calling 1BADTK
Old May 11, 2000 | 01:38 PM
DonH's Avatar
Post Calling 1BADTK
Quick question-- Do you still run the single edelbrock # 5512 MUFFLER. If so would you recommend it. If you can help! Thanks Don
Hambone (2000 Rd Lightning) 32 3 window cp 99 Roadking
Old May 11, 2000 | 01:47 PM
1BADTK's Avatar
Thumbs up
DonH:
Yes I do and a couple of the other HALO club members have it also. Nice sound, soft and mello under normal conditions, loud under full load. Does not make a lot of cab noise with windows up.
Old May 11, 2000 | 01:57 PM
DonH's Avatar
Post
Thanks for the quick reply. I will assume besides the sound quality the power was not affected. Thanks AGAIN DON
(2000 Rd Lightning)
Old May 11, 2000 | 07:31 PM
noelvm's Avatar
Talking
I just installed the 5512 on my truck this week. Sounds great, but not too loud. Perfect mix. I'll see how it runs this weekend but since it flows more than the stock unit it can't be detramental. Since its 2" shorter than the stock unit some mods are required. We removed the old muffler and cut the forward bracket that holds the front exhaust together and mounted there. We took what remained put in vice heated up and beat the tips off. Made new exhaust pipes installed tips, welded together, and then welded the hangers back on. First classs job done by Bumberas performance here in Houston. Runs great, Sounds great. LSR Friday nite.
noelvm
Old May 11, 2000 | 07:52 PM
DonH's Avatar
Post
Noelvn.........Thanks for the info on the install. Thats very important to me-- you know, you just don't want some hack job. Again thanks and will use your plan. Don
Ps Do me a favor and let me know how it worked out this week end.... Good luck
(2000 Rd Lightning)
[This message has been edited by DonH (edited 05-11-2000).]
Old May 11, 2000 | 08:15 PM
Caka's Avatar
Post
Hey Noel, did you put the little screw on chrome tips like mine has? I know how much you like them. Just kidding, I actually took them off and tried to clean the stock pipe, but it was not possible. Had to put the cool tips back on, I guess til I get the Bassani. I better start saving some money.
