Question about Stock Block & KB
Old Apr 10, 2006 | 10:30 PM
Down South SVT's Avatar
A friend of mine has an 02 L and is ordering a Kenne Bell. We are trying to decide what is the safest amount of boost to run with a stock block. Any opinions?
Old Apr 11, 2006 | 07:59 AM
afchad's Avatar
I have stock internals and run a Steig ported blower and every other mod you can do and run about 16lbs of boost. I just purchased a KB and am going to keep it down to about 14lbs and alot less timing.
I personally wouldn't run over 15lbs on a stock long block. A few things I would watch when upgrading to a KB on stock internals. 1. Watch your MAF (probably need to upgrade) to be sure not to peg it. 2. Watch your A/F ratio. Might think about upgrading fuel pumps and injectors. 3. Watch your air charge temps. An upgraded heat exchanger and true CAI is a good idea. Kenne Bell recommends NOT to run an open air filter to avoid sucking hot engine air in.
Just my $.02
Old Apr 11, 2006 | 08:55 AM
brahmus's Avatar
I've been doing alot of research on this exact topic and the consensious is to stay near 14psi for street while some turn it up to 17psi for strip (more than I'd want to) At that point a MAF is a must. Looks like I'll be runing the SCT BA2400. The Injectors will be near thier limit so it's a good idea to upgrade for better tunability and reliablity. (I'm going to run 60#). The fuel pumps should be ok till about 500rwhp on a stock block. Keep an eye out but you shouldn't need to upgrade. I read and read and could probably get away with just a MAF at 14psi (my 2000 has an 80mm MAF, the 90mm MAF may be enough) but I think you are pushing your luck with the injectors. $500 for injectors is a small price to pay to keep your block together. Search through my old posts there are other recent topics on this you can read for yourself.
Old Apr 11, 2006 | 02:37 PM
Learo2000GT's Avatar
not to hijack... but Afchad if you want to sell your ported blower shot me an email at doug@osc-voc.com I am not on the boards much..... thanks Doug
Old Apr 12, 2006 | 06:10 PM
afchad's Avatar
Doug...thanks for the offer...but belive it or not....someone was right next to me when I paid for the KB and said..."I'll take your old blower". I love my Steig ported blower....and almost hate to sell it. Took me into the 11's with only boost. Not to mention...it looks bad a$$
Old Apr 12, 2006 | 09:44 PM
thanks... I just have to put down the cash and get one..... waiting for new tune before I pull the trigger.. thanks Doug
