Where to get remote amp turn on wire?
Old May 3, 2000 | 11:45 PM
EJs00Lightning's Avatar
Question Where to get remote amp turn on wire?
I have searched and found out that some amps don't need one and others do. Well I have a Rockford 250 a2 and was wondering if you all knew if I need a remote power wire. If so where were you all getting it from on the stock head unit. One more question where is the best place to run the amp power through the fire wall at?
Thanks EJ
Old May 4, 2000 | 05:24 AM
Tundra's Avatar
Rest In Peace
From: anchorage, alaska, usa, north america, earth, solar system, milky way
Post
What I did for the remote switch was take some speaker wire and jump it from the main power clamp thingy and put in the remote power switch clamp, of course I made it long enough so that I could put in a real switch. Leaving the amp on hasn't seemed to do any harm, as there is no signal to amplify when the truck is off. I ran the main power cord around the edge of a boot on the driver's side fire wall. I know it sounds shady, but it works just fine for me.
What I want to know is what color is the small ignition wire to the key switch, so I can install my very own kill switch.
I hope this helps
99 Black Lightning
created 8/17/99, bought 9/25/99
#3681/4000
CD changer, Tow package, factory tonneau cover
100k mile warrantee, bed/under liner, paint protected
Old May 4, 2000 | 11:07 AM
svt-tommy's Avatar
Post
i had the same problem on my 98 f150, i went to the library, found an electrical schematic for the radio, and it was one of the wires in the stock unit already. hope this helps.
tom
Old May 4, 2000 | 04:08 PM
ROUSHFAN-1's Avatar
Question
are you using the stock head unit?
Old May 4, 2000 | 07:58 PM
Tundra's Avatar
Rest In Peace
Post
I am using the stock head unit, until I can figure out how I am going to pay for tinted windows.
Old May 4, 2000 | 10:51 PM
Post
to the top, I know some of you have to be running stock head units with amps
Old May 4, 2000 | 11:36 PM
Tiron's Avatar
Post
Well I don't have my factory radio installed anymore, but what I do have is the little book from my aftermarket radio install kit. So assuming the lightning doesn't have any wiring that's too strange, it should give what the wires in the factory harness are. Check out a jpg scan of the page here.
<A HREF="http://tnet.dyndns.org/stereo_wiring.jpg" TARGET=_blank>
"tnet.dyndns.org/stereo_wiring.jpg</A>"
Both G & H on the diagram will accomplish what you need.
1997 F150 XLT Flareside
4.6, Auto, 3.55, custom catback
Pioneer DEH-305, Alpine 3547, 12" Kicker Comp.
[This message has been edited by Tiron (edited 05-04-2000).]
Old May 4, 2000 | 11:46 PM
bomber's Avatar
Banned
Post
when i wired my amo into my head unit i wired the power from the battery with an in line fuse then , to turn it off and on i taped into the antenia wire. so when the radio is off the amp went off.
Old May 5, 2000 | 12:23 AM
ImpalaSS1's Avatar
Post
Hey guys, I have quite a background messing with aftermarket audio equipment. The first move is to buy an aftermarket head unit. Even the $2-300 kenwood base model radios blow away the stock unit. If your goin to keep the stock head unit for now, The best thing to do is run the remote wire from the fuse box to the amp. Pick a low amp fuse, and run the remote wire from the fuse box to the amp. This way when the car turns on, the amp does too. Also, every aftermarket amp has a remote wire. This is how the amp knows to turn on and off, so as not to drain the battery!
