6 Lb lower
Old Mar 28, 2006 | 10:52 PM
Fowl's Avatar
6 Lb lower
I ordered a 6 pound lower to replace my 4lber. I will know soon what the difference feels like. I totally forgot to order a new belt. However, would the belt from the 4 lber work with the 6 lb? I surely hope so. Let me know guys.
Old Mar 28, 2006 | 11:02 PM
gbgary's Avatar
unless your previous belt was slightly loose (too long) it won't work well. you'll really like the sixer.
Old Mar 28, 2006 | 11:11 PM
LightninSVT's Avatar
So, what is the correct size for the 6#? the 75 or 80?
Jon
Old Mar 28, 2006 | 11:42 PM
CoCoCountyLbolt's Avatar
I used the same belt and havn't gotten slip with either pulley.
Old Mar 28, 2006 | 11:44 PM
Fowl's Avatar
Did you buy the belt for the 4 or 6?
Old Mar 29, 2006 | 05:10 AM
evo's Avatar
evo
6#er use a 69" belt w/90mm idler pulley.
Old Mar 29, 2006 | 05:27 AM
Art-Man's Avatar
I have a 6# lower w/ 90mm pulleys and the metco tensioner and use the Gatorback Part # 4080690 ....no slip, no problems...
Old Mar 29, 2006 | 10:21 AM
Fowl's Avatar
My truck has the stock pulleys. I bought the belt for the 4lber and i just wanted to know if it will work with the 6 lb pulley.
Old Mar 29, 2006 | 02:36 PM
01_White_Light's Avatar
A Gate's 67.5 will work. I have factory upper pulley's and a 6lb. lower. Once you get it tuned just right your going to love the 6lb.
Thanks,
01_White_Light
Old Mar 29, 2006 | 04:24 PM
Fowl's Avatar
Thanks,
01_White_Light
Thanks I look forward to receiving the pulley I hear that it is a big difference moving from a 4 lber. Do you feel that additional power immediately from throttle? and i think my belt is a 68" gatorback belt.
Old Mar 29, 2006 | 06:53 PM
To be honest I went straight to the 6lb. pulley from factory. I was entertaining the idea of buying a "LFP" 2 set pulley (Lightning Force Performace 4-6lb. interchangable pulley.), but I was talked out of it because it's a hassel to change and I come to the realization that the 4lb would be stuck in the back of a drawer somewhere once I placed the 6lb. on it. But, it will make a difference for sure!
01_White_Light
Old Mar 29, 2006 | 07:27 PM
SWThomas's Avatar
What is the diameter of a 6# lower?
Old Mar 29, 2006 | 10:25 PM
It came with an interchangable kit that I bought used...so sorry I have no idea.
