Throwing Codes
Old Mar 23, 2006 | 08:00 AM
[03bolt]'s Avatar
Throwing Codes
Just got back from a 700 mile trip, majority of the way was fine until the last 200 miles...Check engine light came on, but no noticeable problems...pulled over and checked the codes and came up with P0136, P0156, P1132, and P1152..anyone have a good idea what to check?
Oh and its a 2003 with 57, 000 stock pullies, full exhaust
Old Mar 23, 2006 | 10:41 AM
Missouri03L's Avatar
Here's the details on those codes:
P0136 - HO2S Sensor Circuit Malfunction (HO2S-12) The downstream HO2S sensor(s) are continuously checked for maximum and minimum voltages. The test fails when the voltages fail to meet the calibrated limits. Pinched, shorted, and corroded wiring and pins.
Crossed sensor wires.
Exhaust leaks.
Contaminated or damaged sensor.
P0156 - HO2S Sensor Circuit Malfunction (HO2S-22) See DTC P0136
P1132 - Lack of HO2S-11 Switch, Sensor Indicates Rich A HEGO sensor indicating rich at the end of a test is trying to correct for an over-lean condition. The test fails when the fuel control system no longer detects switching for a calibrated amount of time. See Possible Causes for DTC P1130
P1152 - Lack of HO2S-21 Switch, Sensor Indicates Rich A HEGO sensor indicating rich at the end of a test is trying to correct for an over-lean condition. The test fails when the fuel control system no longer detects switching for a calibrated amount of time. See Possible Causes for DTC P1130
P1130 - Lack of HO2S-11 Switch, Fuel Trim at Limit The HEGO Sensor is monitored for switching. The test fails when the HO2S fails to switch due to circuit or fuel at or exceeding a calibrated limit. Electrical:
Short to VPWR in harness or HO2S
Water in harness connector
Open/Shorted HO2S circuit
Corrosion or poor mating terminals and wiring
Damaged HO2S
Damaged PCM
Fuel System:
Excessive fuel pressure
Leaking/contaminated fuel injectors
Leaking fuel pressure regulator
Low fuel pressure or running out of fuel
Vapor recovery system
Induction System:
Air leaks after the MAF
Vacuum Leaks
PCV system
Improperly seated engine oil dipstick
EGR System:
Leaking gasket
Stuck EGR valve
Leaking diaphragm or EVR
Base Engine:
Oil overfill
Cam timing
Cylinder compression
Exhaust leaks before or near the HO2S(s)
A fuel control HO2S PID switching across 0.45 volt from 0.2 to 0.9 volt indicates a normal switching HO2S.
If you want, you can shoot me your email and I can shoot some screen shots of the service manual locations of the sensors....
Old Mar 23, 2006 | 05:38 PM
[03bolt]'s Avatar
Thanks, Im gonna pull the sensors tonight and see if their dirty. Would a bad cat cause this? One of my Magnaflow's cats has been rattling for some time now, but Ive never set these codes before.
Old Mar 24, 2006 | 09:34 AM
[03bolt]'s Avatar
What should the 02 sensors read voltage wise....they looked clean. Does anyone have a flow chart for these codes?
