Lightning Tire Pressure?
Old Apr 24, 2000 | 10:01 PM
RoushFan 2's Avatar
Question Lightning Tire Pressure?
For you guys that have put the Roush Sport Suspension under your Lightning - What have you found is a good tire pressure to be running? What does your door sticker say? I've been playing around with mine and it seems to have better turn in with the fronts about 2psi higher than the rears.
Old Apr 25, 2000 | 05:07 AM
GP KART's Avatar
Post
Hey Roush Fan,
I have a 98 ext cab with the Roush stuff on it. I've played with the tire presures only a little. I'm in California and the weather is always kinda normal.60 degrees to 90 degrees. I like 38lbs Front and 32 lbs. Rear
Note: These pressures I find desirable for handling. I know there are allota drag racers here so those numbers may not pertain to everyone. Also these are my numbers for BFG Comp TA's the Goodyear F1 tires are of a harder maybe stiffer construction. I will have my NEW Silver L done by Roush in early May. It will also have BFG Comp TA's and I'll let you know how that combo works out.
Robert
