Need Help ???
Old Apr 24, 2000 | 09:28 PM
Burninout101's Avatar
Question Need Help ???
Ok dont kill me for this but its another tire ? I have 6 choces from TireRack for tires on the truck, I only cheacked for size, dry and wet traction and tread wear. I havent cheacked about the weight i couldnt find where to cheack it at. so here they are
Pirelli; PZero Asimmetric (Rear only) 295/35
dry/wet/tire wear
10/10/9
Bridgestone; Potenza s-02 295/35
9.4/8.2/6.3
Sumitomo; HTR zll 285/35
7.5/7/ n/a
Goodyear Eagle F1` 295/45
8.9/8.5/7.2
BF Goodrich; G-Force t/a kd 295/35
9/8/8
Nitto NT 555 Extreme performance 285/35
n/a
Ok I dont know really crap about tires so i can use some help which ones whould i be better with? Will a 285 be good for the truck, what is thediffernce between a295 and a 285.Also can I say put a Pzero Asimmeter onthe Back and Bridgestone Potenza on the front, So do I have to have the same tires in the front as Ido in the back?
Thanks,
Justen
Old Apr 24, 2000 | 09:40 PM
2000Silverbulletonorder's Avatar
Post
Justen, what are your roads like down there?
For width, I would go for 1) 295 2) 285
For Aspect ratio I would use: 45
Load capacity should only be a factor if you intend to tow or haul, but make sure. The lower load rating will make your wheels more susceptable to damage from bumps, curbs, and potholes.
I like the Potenzas, but the with thin side wall (35), I would be worried about about strike through and ride harshness.
Yes, you can have different tires on the front than on the back, but this will not allow you to rotate tires if they are directional, which I assume all list are.
If you catch me online (IM) we can talk about what works best for you.
Old Apr 24, 2000 | 09:50 PM
4D THNDR's Avatar
Lightbulb
Be sure to get a "Z" speed rating also.
Red '00 Lightning,
Adopted 4/19/00,
PSP Filter,
Track time pending...
