4lb with nitrous
Old Mar 14, 2006 | 11:51 PM
Lightning1983's Avatar
4lb with nitrous
Alright well i ordered a xcal 2 with two custom tunes from jdm...my mods are c&L upper,accufab singleblade,k&n cold air kit,4lb lower pulley and 125 shot of nitrous compucar wet kit...i havent tried it out but i was wondering if you all think 125 will be to much of a shot? i dont go to the track much so its not something i use alot just mess around on the street every once or twice couple weeks with the locals so i dont put alotta passes on it my truck is basically stock so i was hoping the tune will make it ok i live to far away from anywhere to get it dynoed anyways any input would be nice thanks.
Old Mar 15, 2006 | 08:06 AM
halflife's Avatar
Are you a gambling man?
I only have a 4lb, cone filter, and catback and I am scared with the 50 shot I am putting on that the motor is going to puke with my stock block.
Old Mar 15, 2006 | 11:59 AM
brahmus's Avatar
125 is to much!! Especially without a good dyno tune!!
Old Mar 15, 2006 | 03:09 PM
wydopnthrtl's Avatar
Using a fixed hit kit wll limit what you can do. Spray it properly w/a ramped up system and a 125 is about the limit IMO.
I run a 100 shot on top of my 428rwhp and have had zero problems using the racetested kit.
Rich
Old Mar 15, 2006 | 08:32 PM
yea i use to have a 75 dry shot on it and the reason i was thinkin about teh 125 shot with the wet kit is because even with the 100 shot i had on the the wet kit it didnt hit like the 75 dry it felt alot slower.
Old Mar 16, 2006 | 07:01 AM
BRUCEWRS's Avatar
How did you like the dry kit?I am putting oneon now.I will only be using a 50 shot...I just want to cool down the intake charge and reduce the timing alittle..
Old Mar 16, 2006 | 12:30 PM
Just fyi.. that's not going to happen. I did a whole data logging study on this. Not until you start spraying 100hp worth do you see a significant drop in IAT2 temps. (20F)
All a 50 dry shot is going to do is lean out the mixture
Here is a no nitrous graph and a 75 shot graph.
Old Mar 16, 2006 | 12:49 PM
i liked it...it picked the truck up alot
