Guys using the GMS Coil Packs in here....
Old Mar 17, 2006 | 11:14 PM
madferraristi's Avatar
The shim will need to be between .150" and .240", depends on the length of the wire.
I have fixed the problem on every set I have.
Old Mar 18, 2006 | 08:20 AM
LightningToGo's Avatar
How please?
Old Mar 18, 2006 | 09:22 AM
SWThomas's Avatar
Originally Posted by LightningToGo
How please?
+1... How?
Old Mar 18, 2006 | 10:33 AM
SLVRLTNG's Avatar
How please?
sounds like Mike made shims for them by reading his post
Old Mar 18, 2006 | 12:14 PM
SWThomas's Avatar
Does Mike have pic's so we can shim ours too?
Old Mar 20, 2006 | 06:48 PM
Just recieved my COPS From Mark @ LFP on time like always!
Old Mar 20, 2006 | 07:59 PM
SWThomas's Avatar
Nice! I should have mine tomorrow. Let us know if you have any fitment issues with them...
Old Mar 20, 2006 | 10:28 PM
Will know on Thursday.
Old Mar 20, 2006 | 11:41 PM
LTNBOLT's Avatar
I was talking to Jimmy (Dealerjim) about the height difference an insert could possibly make I remembered that my stock plugs were still laying around on a shelf in the garage. I wanted to compare the height of the stock Motorcraft plug vs the NGK TR6. I think this pic tells the story.
My suggestion would be to make then fit the TR6 and should still slide down on the stock plug enough to make good contact. The vast majority of people that buy the coil packs are not running the stock plugs. The TR6 is the plug most used. If someone has a Denso to compare to the TR6 it would be helpful.
Later,
Chuck
Old Mar 21, 2006 | 10:50 AM
brain bypass's Avatar
good observation!
Old Mar 21, 2006 | 12:34 PM
Master Of Pain's Avatar
Later,
Chuck
I think a cross-braided wire section (compressible, like a chinese finger puzzle)
would provide the tolerance relief and still maintain spark integrity.
Old Mar 21, 2006 | 01:33 PM
SILVER2000SVT's Avatar
Don't think that would work. Sort of defeats the whole design principle of being able to snap it on the top of the sparkplug, if it compressed it wouldn't be stiff enough to make the connection.
Old Mar 21, 2006 | 10:58 PM
SWThomas's Avatar
I got my GMS COP's today. I installed them with some BR7EF's gapped at 0.032. Everything seems to run great. It actually feels smoother and idles better. I only got into boost about 5#'s so I couldn't tell if the spark is going to blow out under higher boost.
The first COP I installed fit just fine. I didn't have to trim it at all. All of the rest of them were too long. I cracked two of them, but the tab didn't break off. They didn't crack bad enough to warrant me returning them or feeling iffy about leaving them installed. I had to trim 6 of them. I preyed the connectors apart, pulled the cable, trimmed off about 1/8", and then re-crimped them. That worked great. They all seated fully and I didn't crack anymore.
Changing the plugs wasn't as bad as I anticipated. It was actually pretty easy. Just a little time consuming. All and all I am pleased with the COP's. Even though I had to trim them a little. I will get out on the road when it warms up a little and see how they perform under full boost.
Old Mar 22, 2006 | 05:37 AM
SWThomas's Avatar
I've got two questions for you guys since no one is paying any attention to my thread...
1. These are my old spark plugs. How do they look? One of them had oil on it when I pulled it. What does that mean?
2. Will running colder spark plugs in really cold weather increase the chances of fouling them out? I was running TR-6's before and I don't want any problems with the BR7EF's.
