The Ultimate Underhood Bling!
Old Mar 8, 2006 | 06:31 PM
Odin's Wrath's Avatar
Well, I guess that would be anti-bling.
More:
http://img.photobucket.com/albums/v2...le003forum.jpg
http://img.photobucket.com/albums/v2...le002forum.jpg
http://img.photobucket.com/albums/v2...le001forum.jpg
Old Mar 8, 2006 | 06:37 PM
Stock motor power numbers to follow. Just waiting on the files to be sent.
This blower is insane!
Old Mar 8, 2006 | 06:42 PM
MITCHYKINS's Avatar
I LIKE IT NICE clean install not to much shiney gooking it up
mitchykins
Old Mar 8, 2006 | 06:57 PM
mitchykins
Thanks,
David, at Dynamic Autoworks in Charlotte, did a wonderful job. It looks absolutely like it came from the factory this way. Excellent work! Very clean. I can't recommend him for Lightning work enough. He really knows these trucks.
Old Mar 8, 2006 | 07:04 PM
Ricki F-150's Avatar
That's a neat looking install mate.
BLACK is BACK
The pinch roller on the top pulley should ensure some grip at WOT
Who made the extra pinch idler set up ?
Old Mar 8, 2006 | 07:29 PM
BLACK is BACK
Thanks, you can get the Metco Idler from CHiCkENeArS.
http://www.chickenears.com/metcoidlerpully.htm
Old Mar 8, 2006 | 10:51 PM
CoCoCountyLbolt's Avatar
I bet that makes your spark plug changes a bundle of fun!
Old Mar 8, 2006 | 11:58 PM
lovetrucks's Avatar
BLACK is BACK
Or......BACK IN BLACK!
Old Mar 9, 2006 | 01:20 AM
Fowl's Avatar
I did not realise that until you mentioned it. Is is going to be really difficult to change the plugs on the right.
Old Mar 9, 2006 | 09:57 AM
brahmus's Avatar
Go denso and then you won't have to worry!!
Odin, how much boost do you plan on running through her? Stock motor correct? Do you have a list of supporting mods?
Old Mar 9, 2006 | 10:58 AM
I have 60# injectors, 2400 SCT MAF, LT-headers, 6# lower, and the 3.375 pulley that came with the Whipple. Not my only mods; but, thiese are the key ones. We found that I was making more power than I expected and now need to upgrade the pumps, too. We pulled the timing back to 12* and have the fuel down to +/-11.0 most of the way across the graph. At 5200 rpms it's still below 11.6. We couldn't pull enough power out though. 480+ rwhp 600+ ft/lbs is where we ended up. I hit the 500/600 club. First pull was over 490 hp and everyone just about crapped. There's more to tell; but, I need to save it for later.
Old Mar 9, 2006 | 11:15 AM
Marc Carignan's Avatar
Thumbs up
OMG those are great stock block #'s... and relatively safe/conservative a/f & timing! When my warranty is up that's my first mod (along with the injectors, pumps and MAF), you've decided it for me... plus it looks great!
Old Mar 9, 2006 | 11:24 AM
Intake temps stayed around 110* with back to back to back to.....etc. pulls. We made 514hp without breaking 14.5* of timing. At 5200 rpms we still hadn't broken 12.0 on the A/F. By 5500 we had though. The pumps were not there anymore. I'm pretty stoked about it.
WOOO-HOOO!
Old Mar 9, 2006 | 11:36 AM
brahmus's Avatar
What does that register on the boost gauge? Any suggestions for someone that doesn't want to upgrade MAF, Injectors, Pumps? Whats the psi limit?
Old Mar 9, 2006 | 11:42 AM
Not sure about the boost. According to Whipple, somewhere between 14-16#. If you're thinking about a blower like this one, I wouldn't shirk the MAF, injectors, or the pumps. (I skipped the pumps; but, in retrospect, I shouldn't have.) Tuning will be easier and the peace of mind is worth every penny.
