Exhaust Tip Location
Old Mar 23, 2000 | 10:37 PM
WHAT04's Avatar
Question Exhaust Tip Location
Of the various pictures that have been posted showing our exhaust tips, it would seem that there is a wide variance in how low the tips drop below the cutout.
Mine hang quite low, like the top of the tip is almost below the side skirting bottom edge. Some that I have seen are nestled nicely up in the cut out.
Looking at the exhaust system, it would seem that all that is required is to loosen the clamp at the front of the muffler, and twist the muffler and tips upwards. Re-tighten and Voila.
Am I right? Anybody done this?
2000 Red Lightning Born 3-8-00 / Delivered 3-22-00
'99 Yukon Denali - Silver, Lowered 1", Borbet CW4's, 285/60R18 Toyo Proxes S/T's, Hotchkis AntiSways, Edelbrock Shocks
2000 Red Trans Am Ram Air WS6, 6 Speed - Delivered 2-15-00 - Awesome Looking Car
[This message has been edited by WHAT04 (edited 03-23-2000).]
[This message has been edited by WHAT04 (edited 03-27-2000).]
Old Mar 23, 2000 | 11:44 PM
BABolt's Avatar
Talking
Up tight like this.
BABolt
SVT#290
Old Mar 24, 2000 | 09:58 AM
jesus romero salas's Avatar
Post
BABolt
How did you do that to your tips and the shine to I like
99.5 lightning
super chip
downford filter
headlight and fog light bulbs care of (Roger) great lights
alpine head unit
upgraded speakers
dyna mat all over
soft cover soon to be hard
cervini (soon)
looking cross drilled rotors front & rear
Subaru wrx sti ver2
4 wheel drive
turbo intercooled
blue with gold mags
water injector
oil cooler
4 piston brakes
greedy exhaust
greedy profect (boost controler)
greedy turbo timer
cusco shift light
quick shift
cusco lower and upper strut bars
Old Mar 24, 2000 | 06:19 PM
Tundra's Avatar
Rest In Peace
From: anchorage, alaska, usa, north america, earth, solar system, milky way
Post
Make sure you clamp the muffler tightly, I have loosened the muffler twice just by stepping on the gas pedal, and I had the exhaust re-torqued by the dealer, since I paid for the extended warrantee and I did not want to risk voiding it in any way. It looks nice though, really tight.
PS How did you get the tips so shiney? I have about 4000 Alaskan miles on my truck and the tips are begging to be cleaned right. thanks for the info.
Old Mar 24, 2000 | 06:55 PM
BABolt's Avatar
Talking
Hi!
Made a new exhaust system last year (June 99) out of 304 stainless from the cats back used two Borla stainless mufflers (polished too). Then I polished the last 3 feet of the exhaust to a high shine and then polished the inside too. Looks great with the chrome wheels.
BABolt
SVT#290
Old Mar 24, 2000 | 08:02 PM
Twisted99's Avatar
Post
Cut my muffler off and put in pipes. Retained the factory tips. I did adjust them up..they hung way low. They are close to BaBolts as far as placement and look much nicer there.
Jeff C.
Old Apr 16, 2000 | 11:53 PM
'00BlackLightning's Avatar
Question
Has anyone tried to move up the tips as suggested above? Looking at it, it seems more involved than just swinging up the muffler.
2000 Black Lightning, Snuglid,Clear corners,Lightning banner
delvered Apr 6. NLOC #377
Old Apr 17, 2000 | 07:41 AM
WHAT04's Avatar
Post
I've tried. We loosened the bolts at the cats and then heated the hangers at the rear of the muffler and by the exhaust tips. Bent the hangers to get the tips nicely snugged up and tightened everything. Looked great.
Started the truck up and got a lttle buzz under the passenger seat when turning. Had a 220 pounder sit in the passenger seat and suddenly the muffler was buzzing off the heat shield right under the passenger seat.
Returned everything to normal and am now just living with low tips. In the end I would say that they are slightly raised.
The heat shield could be removed and flattened somewhat. It has a crease right over the center of the muffler which makes clearance a little tight.
