New Fan Controller replaced FAL VSC w/ SPAL
Mostly Informational:
Several months ago I posted about my Flex-A-Lite VSC Controller melting on my L for the second time. I have another friend with the same controller on his L and he's had the same thing happen as well...(Carnage photo from mine is below).
I spoke with Flex-A-Lite at SEMA and the rep acknowledged they were having a problem with their Mfg and advised me to send it in...again. I waited, searched here and at some other sites and finally found a replacement I was happy with..SPAL (They mfg the unit BeCool uses)
It was $99 at Automotive Engineering here locally in the Tampa area, I've spotted them on e-bay for $79 + shipping... "I Want it NOW" syndrome cost me the extra $20.
Two speeds, 60% and 100%, sealed unit in an extruded aluminum case, very easy to install, it connected to my Autometer temp gage sending unit (Just tapped in on the wire), has the AC input, and is fully programmable to your specific temp requirements for the two speeds.
The old FAL VSC Controller:
New SPAL Unit:
Installed:
Also installed a quick disconnect I picked up at Grainger between the unit & the Fans for servicing...
Part # 3BY20 - Grey
Part # 3BY21 - Red
Overall, I'm pleased with the unit...I've installed two now and both have been working well.
New SPAL Unit:
Installed:
Part # 3BY20 - Grey
Part # 3BY21 - Red
Hi,
How are your SPAL controllers holding up? I've been reading about problems others are having with their controllers and don't want the same trouble.
Did you get 2 controllers? 1 for each fan? What are the Max temperature range of these controllers? I just bought the Troyer kit and don't want any trouble with the controllers.
Originally Posted by Padron
Hi,
Hi,
Any updates on these SPAL controllers? I just had a Troyer controller die after less than one year and I don't want to keep replacing them at $50 + shipping each.
