Timing
Old Apr 11, 2000 | 05:43 PM
William Mallo's Avatar
Post Timing
Drove home today with my scanner hooked up . So I could watch timing with chip on and off. Max advance in stock mode was 38(saw on desel). Max saw in performance mode was 50(too much). Holdind at stop light at 1000rpm,stock was 23,per was at 33-34, both at same throle opening. At wot under boost stock was 11-15,per was 23-25. At cruise 50ish with steady throtle, stock was 33-37, per was 45-50. On tip in stock was 33-36 and drop to 26ish. Per on tip in was 45-49 and then drop 37-43. I looked at alot of speeds and would change from one to the other at same throtle angle to see difference. Performance was 10 or more above stock settings. I think that in higher gears that engine does not need so much timing under vacume. Will posily cause problem with rings or pistons sonner ro latter. What do you guys think ?
99.5 Black Lighting
#1277 5/14/99,got 5/26/99
CD Changer,Tow Pack,Ford Bed Liner,2in drop Shackles ,Tinted Windows,4lower Stoplights, Soon PSP Chip+Filter
2000 Mustang GT
Convertible,Performance Red,Black Top,
Cobra R Wheels,BFG Tires, Bassani X Pipe, Flowmaster Mufflers / Stock tips , K+N filter with air silencer removed
Old Apr 11, 2000 | 05:56 PM
Silver_2000's Avatar
Post
What is Tip in ??
Doug
Old Apr 11, 2000 | 06:04 PM
TampaBayLightning's Avatar
Post
We think you have too much time(ing) on your hands....(g)
Rich
1999.5 SVT Lightning - Red. Super Chip. K&N Filter. Viper Alarm w/remote start, Sir Michael's roll pan, smooth corners and steps w/billet inserts, clear corner lenses, tow package, cd changer, cover, Phantom boost gauge, MTX Thunderform w/ 2 10" MTX 200w. subs. 5-channel 500w. Clarion amp.(APA5241), (4)Polk Audio 3-way, 130w. DX 7's, Muth signal mirrors, Soundproofed cab, BedRug, AIM 2" Drop, etc. Build #2755
TampaSVT@Tampabay.rr.com
http://home.tampabay.rr.com/tampasvt...Lightning9.jpg
1999.5 Expedition XLT
Old Apr 11, 2000 | 07:18 PM
Post
Silver2000
Tip in is when a give more gas to take off or to accel when driving. Like running 55 and tip in on throtle to speed up to pass or if 55 is to slow .
Tampabay
This is with psp chip that Bill is letting me use. Bill had the same problem(I belive). It has rattling.
99.5 Black Lighting
2000 Mustang GT
Old Apr 11, 2000 | 10:17 PM
LightningTuner's Avatar
Post
That chip that you are using Will, is one that is a few calibrations old. I have revised the timing for less tip in ping as well as more WOT power since that calibration. If you had a the new version, you'd feel the difference.
SAL
13.209@104.3mph
Power Surge Performance 99 Lightning Chip and Filter Kit, full Bassani Exhaust, Nitto Extreme Drags
PowerSurgePerf@aol.com
Old Apr 11, 2000 | 10:58 PM
Post
Sal
Can't wait to get new set up :-)
99.5 Black Lighting
2000 Mustang GT
