Blown motors(Past and present)
Originally Posted by Edward Goodell
Yes i do believe that the cold weather brings out plenty of blown motors. What many people are forgetting is those RETARDS that do their 60 mph kickdown to 100+. (sorry if i offeded anyone) but time in and time out the same old story" well a vette on the highway pulled up next to me and wanted to play" " i got on it about 60 mph and i heard a big boom a few seconds later." doing kickdowns is a big difference in load capacity compared to 0-whatever mph at the track. Yes you can blow at the track but i bet over 80% of people that blew their engines on this forum was by doing 60-70mph kickdowns.
Alledgedly
Can't hurt, can it?
Originally Posted by 1flightmedic
Today, Feb-23rd at 9AM; 45 degrees at about 100-110 WOT with a new mail order tune from a popular vendor and a new stage 4 steig port SC. Personally, I dont think it was the tune...I think 45 degrees was to cool for this set up on a stock block. IMO
Was the tune from a guy with a four letter name? Or one of the 3 letter name guys?
45 isnt to cold, I am in Canada and I run a 6 lower ported eaton and a 75 shot fine.
Kickdowns or higher runs put stress on the engine, if your tune cannot handle it, your done.
Get a Wideband.
yeah
You guys gotta stop running Mail Order Tunes.
When I got my Mail-Order Predator tune from one of the biggest and well known tuners I was told it would be a flat 11.8 across the board.
Well I went to dyno it a couple weeks later and It was a straight line for sure but at 13.5 af ratio.
Was he willing to fix it? Sure. Was I about to let him? Hell no. What if I didnt get a dyno? I would be fuked.
Get a dyno tune, anyone with a dyno can tune it properly, just make sure the a/f is what you want it as well as the timing, its not some miracile that these mail order guys perform, and they are just canned tunes for the most part.
Never knew if his was lean or not because he bought a 2003 after than which used a different chip. Just goes to show how different each and every truck is.
Anyone else see the post on the difference on stock cam shafts??
Like the saying goes, be carefull on discounted prices when shopping brain surgery, parachutes, and medical/dental care. Add tunes to that list.
Get dyno tuned, or at least get an a/f so your tuner can dial you in. If you are running in cold weather, make sure your tuner knows that.
for someone whos uses their brain when driving these trucks.
Still running like a top. Almost 100k miles. Guess I'm RETARDED.......If I couldn't do that, I'd be in a Mopar.BD
Heres my opinion, why bolt on parts without getting a tune? It makes no sense to me to just bolt on a box of parts an hope it works out, on top of being risky your not going to get the most out of your upgrades. Todd
Originally Posted by supeg
Of course it was the tune, you leaned out. What else caused it? You blow when you lean out, kickdown or not.
Get a Wideband.
Get a Wideband.
Is this your first attempt to educate someone on this subject? If the MAF or a Fuel pump fails its not the tune...I dont know if you know that or not."45 isnt to cold, I am in Canada and I run a 6 lower ported eaton and a 75 shot fine."
So whats your point? I have a friend with a 2000 running 15 psi a ported blower and NO tune on a truck with 115,000 miles...oh, he runs it in any weather. He broke all the rules. 60+ mph kickdowns all the time....Still running strong.
You can get lean for many reasons. I dont think the question is if it was lean. The question was how it got that way...
If your pump "failed" I think you would know it.
My point is, I got a good dyno tune. Therefore I can do kickdowns in any weather without blowing it, when I got my mail order like I said before my A/F was at 13.5.....
Did you get it checked out to see what happened? If your fuel pump went out, or your MAF "failed" then you should already know so.
A Dynotune would also let you know if you are pegging your MAF Voltage.
Bottom line, if you get a mail order tune and you dont have a wideband your playing with fire, but then you already know that now
So who was the tune by? RWTD? PSP? JDM? LFP? JLP?
I wish we knew exactly what happened on most of the kickdowns that caused blown motors.
Is it?:
1. Too much timing from the cold weather computer reaction?
2. Lean spot when mashing open the throttle blades?
3. Somthing about kickdowns that shocks the rods?
If you turn off overdrive before stepping on it at highway speeds, is this something that makes a big difference toward NOT blowing up these motors?
How many have started in 3rd gear from a highway speed and still blew it up?
Is it?:
