What kind of cleaner???
I was just wondering what kind of cleaner you guys are using to clean your MAF. I just re-oiled my filter and every so often the SES light comes on.l I'm guessing some oil got sucked into the MAF. How do i go about cleaning it and what do i use Thanks
So you guys are just spraying it on the little hair? Then what? Are you leaving it on there or blowing/wiping it off with something? I have 34K miles on my L and have never even heard of cleaning the MAF. I would like to do this if you guys could hook me up with the info.
Just spray with contact cleaner, let dry 5 min. and reinstall...that's all that is to it. Don't touch the wire! It's soo easy...get in the habit of cleaning every time you change oil and you should never have a problem related to a dirty maf.
Thanks for the info.
I wouldn't think that under normal opertain conditons - as long as you're using a filter that you'd have to clean your MAF very often, if at all. But if for a little extra insurace, it wouldn't be a bad idea to do it with some regularity. It's a good idea to do for those that use the K & N Filter cleaner - after you've cleaned and and installed your filter - and ran it for a while just in case you've "over oiled" the filter and some oil residue from the filter may get onto the MAF wire.
