Question for those with remote starter.
Old Feb 15, 2006 | 05:21 PM
Rick Zurzolo's Avatar
I just had a Ford remote starter kit installed and discovered that it will not start truck in cold weather. Tech installer thinks that because I have the Superchip flip chip, it is defeating the starters ability to adjust air/fuel on cold start. Since I switch the chip to street tune in cold weather anyway, is there any problem just unplugging the chip for the winter? Remote starter works fine as outside air temp rises. Any thoughts???
Old Feb 15, 2006 | 06:36 PM
Fast95Z's Avatar
I just had one installed a couple months ago so this might be a wrong answer. It is possible you need to extend the crank time to give it a little more time to turn over. I know on mine the crank time was adjustable.
Old Feb 15, 2006 | 07:58 PM
SILVER2000SVT's Avatar
Does it just turn over and never fire? If so it's most likely the PATS defeat. I have that problem in the summer time. There was an involved thread on NLOC about 6-9 months ago about this problem.
Don't know if this is your problem or not, but search for the title "remote start advice" on NLOC
Old Feb 15, 2006 | 10:08 PM
SVT_KY's Avatar
I ran remote start with the Superchip for years ... We did need to advance
the crank time and also the RPM limiter to accommodate the VROOM mod.
Old Feb 15, 2006 | 10:16 PM
whip's Avatar
Hmmm, mine won't start when its hot out. I'll have to search for this thread unless you can find it for me!
Thanks!
