coolant leak
Old Jan 28, 2006 | 07:20 AM
64SPRINT's Avatar
Question coolant leak
I got a leak at the rear of the engine and can't see where its coming from. Its a '99 intercooler has been upgraded. does anyone know what it might be? Took it to son-in -laws garage last night. Told him about this site & he suggested I post this to see what you guys think. Thanks,Nick.
Old Jan 28, 2006 | 09:29 AM
SLVRLTNG's Avatar
check the coolant lines that go to the intercooler. Right behind the blower is where they connect. If you shine a flashlight back there you'll be able to see if there's a leak, that's how I found mine.....
Old Jan 28, 2006 | 09:56 AM
l-menace's Avatar
Is you Innercooler reservior low and leaking, or engine coolant? They do not mix.
Old Jan 28, 2006 | 05:25 PM
64SPRINT's Avatar
I'ts engine coolant don't know whats back there that can leak . heater hose maybe?
Old Jan 28, 2006 | 08:31 PM
l-menace's Avatar
The only thing I can think of is that there is a freeze plug on the rear of the head that might not be fully seated and allowing some coolant to seep out.
Now if it were I/C fluid that would be a different story.
Are you noticing a lack in performance? Is the engine running HOT? These would seem to indicate a leaky headgasket, allowing coolant to enter the combustion chamber area. But that would be easily noticable.
Old Jan 28, 2006 | 09:39 PM
64SPRINT's Avatar
No, No problem with temp or running. Just when I park it runs out under neath. I really can't tell where from Was just wondering if someone else had this problem? Can tell its engine coolant cause its a little low. intercooler level is fine. Thanks for info, Nick
Old Jan 29, 2006 | 07:35 AM
SVT_KY's Avatar
If it's the passenger side I would suspect the head has lifted. It it's coolant
for sure, otherwide it might just be A/C condensate. The heater hose
connections are in the vicinity also.
Have you put it on a rack?
Old Jan 29, 2006 | 09:57 AM
promodlightning's Avatar
I seen 2 similar problems. Its one of your heater hoses. The way they wrap around and burst would cause you to think it was something else.
Old Jan 29, 2006 | 10:18 AM
l-menace's Avatar
that makes perfect sense!
