ASP Pulley....MUST READ
Old Feb 23, 2000 | 05:25 PM
Spiro99SVT's Avatar
Thumbs down ASP Pulley....MUST READ
Well, after installing this pulley.I decided I wanted to remove it and replace it with the stock pulley.I figured since the pulley swap went so well,I figured it would be no problem.Me and a friend attempted to remove the ASP pulley, we realised that the flimsy aluminum puller started to bend. So now we knew we had a problem.We thought maybe the SVT was still warm so we let it cool down to let the metal contract.After repairing the puller we attempted to remove the pulley again...no luck the pulley was now starting to collapse onto itself.The pulley was now crushed against the blower snout, we were not able to rotate the blower by hand
We attempted to heat the pulley hoping it would expand enough to pull it off...no luck.
So, now we knew we were in serious trouble.After some planning we came up with 2 choices.
-Remove the blower and hope to find someone to press it off.
-Slowly cut away at the pulley.
We felt confident that we would be able to cut the pulley away.After a hour of prepping(hood off) the SVT for surgery all we had left was the blower snout exposed in the engine bay.We started with a Dremel tool slowly cutting chunks off.Now with the outside of the pulley cut away,we could work on were the problem is.We spent a hour and a half cutting away at the core of the pulley with a Dewalt 4.5 inch grinder . All said and done we were able to remove the ASP pulley in 7 pieces...yes 7.With alot of patience we able to do this without even knicking the blower with the grinder...Thank God.
The tolerences on the ASP pulley are way off.There is no reason for anyone to waste the money on this pulley.The craftmanship is SH*T, the metal is soft and flimsy.I am now out 300 dollars. ASP takes no responsibility in this.So at least I can share this information with all of you,before someone else makes this mistake.
By the way,the few of you that have installed the ASP pulley have you tried to remove it??
99 SVT Lightning
BLK. #1476 5/20/99
2 Chamber Flowmasters
Downs Air Intake
B.F.Goodrich Drag T/A`s
Superchips
Cervin`s 3-inch Cowl Hood
A-pillar Phantom Boost Guage
Redline Water Wetter
Sportmaster Flip tonneau
Tow package
CD changer
Best run to date
13.064 @105.33
"Empty Pockets Racing"Drag Race Team NJ-DE
LAUNCH HARD
Old Feb 23, 2000 | 06:33 PM
mswaim's Avatar
Post
Boy, what a mess. I'm glad you were able to remove the pulley with no ill-effects. Just goes to show though how valuable such a forum is to fellow enthusiasts. I would venture to bet that anyone who has not already decided to purchase an ASP pulley, will most likely decide not to. (and think of how many Lightning owners you are able to reach all at once and provide such a warning)
Mark Swaim
1999 Lightning (sold)
1997 Cobra (deceased)
1993 Cadillac Allante
Old Feb 23, 2000 | 07:24 PM
isa4325's Avatar
Post
Put it on took it off and put it back on again. Very easy and did it while tied down on the dyno. Something strange going on here, should not have been all that much trouble. I even used a borrowed pulley puller. Sorry to hear about your troubles, but it is a price we pay to play with these toys sometimes. Shame too, HP increase in marginal but every little bit helps.
Old Feb 23, 2000 | 09:16 PM
SCOTTODOG's Avatar
Question
isa4325 how much horsepower did you gain with the pulley installed.
