k&n
Old Dec 10, 2005 | 08:12 PM
64SPRINT's Avatar
Angry k&n
Installed an intake the engine is showing a ses on dash I think everthing is right but the the tube for the idle air might be a little crimped .Would this cause this? probably didn't explain it good enough but you guys will understand. THANKS
Old Dec 10, 2005 | 08:16 PM
netoje's Avatar
Did you make sure u connected everything back together. MAF sensor, IAT sensor, and the 3 vacuum connections at the bottom of the elbow?
Also try disconnecting the battery for a few mins. and reconnect it too see if it shows up again. Good Luck!!
Old Dec 10, 2005 | 08:17 PM
Missouri03L's Avatar
I have a kink in on of my hoses that goes into the bottom of my intake with no problems.
If you're sure of your connections, use a predator or code read to see what the SES light is throwing. If you don't have a code reader you could take it to Autozone or such and they'll read your codes...
Old Dec 10, 2005 | 08:34 PM
64SPRINT's Avatar
I just put it on think i did everthing right but have to double check 3 lines on bottom connected . don't have a code reader Probably have to search Just hopeing someone knew
Old Dec 10, 2005 | 09:09 PM
64SPRINT's Avatar
need help guys! Do you think it's just a line off or not sealed or something?
Old Dec 10, 2005 | 09:35 PM
Ruslow's Avatar
To much oil!!the factory I think just drops it in aoil bath and then packages it up.They are suppose to have just alittle bit of oil[just red color]It more than likely lput an oil film on the MAF.sTan
Old Dec 10, 2005 | 09:40 PM
netoje's Avatar
I just installed this same kit about a month ago. The instructions require you to cut the plastic hose that comes from the passgr. side of the plenum to make the vacuum hose fit under the elbow. Did you do that?
Also make sure that not only are the vacuum lines connected TO the intake, but that they didnt come off on the other side. I found the hose coming off the valve cover to the elbow disconnected at the valve cover. Im almost positive you have a vacuum leak.
Be patient. Take a breather or drink a beer and go back and check again. Sometimes we can't help but miss the obvious things. Good luck! Keep us updated.
Old Dec 10, 2005 | 09:50 PM
64SPRINT's Avatar
netoje I think you may be right but I already had tooooo many to look tonight! but thanks guys I can count on YUNZ.I'll try again in the morning.
Old Dec 11, 2005 | 08:03 AM
wydopnthrtl's Avatar
Check everything for leaks. If not..... then take some "electrical contact cleaner" and spray down the MAF wires (two of them) DO NOT TOUCH THEM!! Reset the computer (batt disconnect & lights on/off)
If that does'nt work then go to your local autozone and they'll scan it for free.
Rich
Old Dec 11, 2005 | 10:56 AM
l-menace's Avatar
Rich
Old Dec 11, 2005 | 12:13 PM
Shorty's Avatar
Originally Posted by l-menace
Old Dec 11, 2005 | 12:33 PM
64SPRINT's Avatar
Are you talking about where it plugs together or some where else?
Old Dec 15, 2005 | 06:14 PM
64SPRINT's Avatar
Contact cleaner worked! Thanks a million.
