Soundproofing
Old Feb 12, 2000 | 12:51 AM
Nathan's Avatar
Post
Try rolling down the window 1/4 inch before you close the door. Pressure problem solved.
Old Feb 12, 2000 | 01:26 AM
whitelight's Avatar
Post
OK, I give up. Could someone tell me where the air extracters are.
Thanx!
Old Feb 12, 2000 | 08:25 AM
lightning's Avatar
Post
Whitelite
The air extractors are located behind the driver and passenger seats. They let in quite a bit of road noise. I think we did leave a little area on the extractors open just in case.
White lightning
#320
PSP full meal deal
Bedrug
Snudlid
Kicker amps.MB Quarts comp.2 Kicker 10" subs
Valentine one
Old Feb 12, 2000 | 10:02 PM
Steve Bopp's Avatar
Post
Ford says to leave the air position selector switch anywhere but OFF, so the truck can breathe. Why is this necessary if the air extractors are already providing for natural ventilation?
99.5 White Lightning.
#3299, Built 8/5;
Snuglid, Bedrug, PSP filter, window tint (limo back, 70% sides).
Old Feb 12, 2000 | 10:48 PM
roger's Avatar
Post
Steve;
the air extractors (2) are about 3"x7" or thereabouts and are located on the back cab wall a few inches inboard from the edge. Each has several small rectangular rubber flaps that fly open when you shut those big ol' doors and relieve the pressure spike so the doors will latch with minimal effort.
They will also bend outward slightly when the HVAC system is in operation (relieving pressure in the cab). This allows a much faster air 'turnover' time, which is one reason why the (litigation) manual states to leave it 'on'.
If you want to see what they look like, take a peek down between the bed and cab. If you want to take one out, the easiest way is from underneath, where you can get to the locators on the outboard side of each post with a small screwdriver or pliers. Take a peek and it'll be obvious. (They come out from inside the cab.)
Word to the wise: If you decide to take one/both out for a peek, be 100% positive you get them back in correctly and all 4 locators are seated/locked or you have a ready-made water leak -- guaranteed. There is also a bead of a sealer material around the perimeter so be careful where you put your fingers <g>...
Some folks I know have sealed off a few flaps, but that just makes the others open wider to compensate -- ymmv...good luck!
Roger Walker
Black 99.5 #1469
Built: 20-May-99
NLOC: 0307
Old Feb 12, 2000 | 11:39 PM
roger's Avatar
Post
Hey TBL; something I almost forgot...If you decide you'd like to remove those air extractors altogether but aren't sure what you'll do with the large hole it leaves, there may be another option. F-150's that are sold in Mexico (called LOBO's) have a dummy extractor to fill the hole. If you're interested I can get a part number for you.
<Disclaimer> I have no idea how long it would take your dealer to get...you'll have to bounce it off your parts counter man to determine cost and availability.
Anyways TBL, howz the install going on the cab? Are you planning on putting some dynamat on the footwell (underneath where the floor mats would go)? <hint, hint>
Roger Walker
Black 99.5 #1469
Built: 20-May-99
NLOC: 0307
Old Feb 13, 2000 | 05:26 PM
TampaBayLightning's Avatar
Post
Roger:
Sealed the holes w/ multiple layers of Dynamat. It's more than airtight now. Thanks though.
I've included pics of the process. Be warned, the photo's can be quite graphic.
The truck was completely gutted (seats, carpet, all moldings and trims, wiring, etc). A thick layer of Dynamat Professional was layed in place, heated, molded to all contours.
Rich
1999.5 SVT Lightning - Red. Super Chip. K&N Filter. Viper Alarm w/remote start, clear corners, tow package, cd changer, cover, Phantom boost gauge, MTX Thunderform w/ 2 10" MTX 200w subs. 5-channel 300w Clarion amp., Polk Audio 3-way, 130w DX 7's, Muth signal mirrors, etc. Build #2755
TampaSVT@Tampabay.rr.com
http://home.tampabay.rr.com/tampasvt/images/Light21.jpg
1999.5 Expedition XLT
Old Feb 13, 2000 | 05:29 PM
Post
Here are the pics of the Dynamat. After that was all in place, a thick coat of rubberized undercoat was applied.
Wiring was put back.
BTW, who ever had the idea of relocating the CD changer under the pass. seat(left side). Thank You!!!!
Old Feb 13, 2000 | 05:31 PM
Post
For those of you who had any doubts.
What a difference!!!!! You wouldn't know the stereo was on from the outside with the doors closed. Really blocked out the exhaust and road noise.
Kinda glad it's over.
Rich
Old Feb 13, 2000 | 05:44 PM
BABolt's Avatar
Thumbs up
Hey TBL
Do you have any ET/MPH results prior to the install of the sound deadening material or do you have an idea on the added weight. Not that it really matters. I am really impressed with you install, first class craftsmanship all the way. May I add the install photos to the Lightning collection at Zing.com. Please advise.
BABolt
SVT#290
Old Feb 13, 2000 | 06:01 PM
roger's Avatar
Post
TBL: My hat is off to you. Awesome job! I do like your level of attention to detail.
Soo, not to be too nosy, about how much do you think that set you back for materials?
Roger Walker
Black 99.5 #1469
Built: 20-May-99
NLOC: 0307
Old Feb 13, 2000 | 10:36 PM
Pacecar18's Avatar
Talking
Hey TampaLightning, I was wondering if the smell from the rubber undercoating is lingering in your truck or if its even noticeable? Excellent job on everything though, it all looks great.
Nothing I hate worse than listing to tires humming or my own exhaust wailing. Its ok if other drivers on the road have to here it!
[This message has been edited by Pacecar18 (edited 02-13-2000).]
Old Feb 14, 2000 | 07:20 AM
Post
BaBolt: Thanks. Help yourself to the photos. I calculated a total of 52sqft. of Dynamat, 2 cans of rubberized undercoat and a few pieces of foam. The total weight shouldn't have exceeded 25 lbs. max.
Roger: Total cost was about $175.00 and about 12 hours of time.
Pacecar: There was a slight odor from the rubberized coating yesterday, seems to be gone today.
Rich
Old Feb 14, 2000 | 10:59 AM
DHFerguson's Avatar
Post
Tampa-
Check out this thread: https://www.f150online.com/f150board...ML/000001.html
for information on underhood sound blanket.
'99 Black Lightning #1212 5/12/99
Old Feb 14, 2000 | 06:36 PM
Spyder207's Avatar
Question
TampaBayLightning,
What brand of undercoating did you use? I've heard that some brands leave an odor for months, while others take weeks to dry. I'd love to do the inside of my truck, but want to make sure I use the right brand.
1999 F-150 XLT Supercab
Black factory steps
Flareside Sport Package
Oxford White
Full tint
Bug Shield
CD player
17" wheels, K&N
Ford Soft Tonneau Cover
Gibson Super Truck
"Did it myself" Undercoating
"Freak on a Leash"
If you've ever purchased online, please visit my new site and post your experience: Online purchasing experiences good and bad.
