Breaking up on the top side????
I thought I had a coil pack going bad...after I melted a few plugs because the truck was breaking down pretty bad at wot. I found a dead cylinder...not good. A melted ground strap off of the spark plug had gotten hung inbetween the valve seat and valve hence a hole burned in my valve.
I'd take it easy on it until you find the issue. I burned five plugs running lean and damaged 10 valves.
wjm
wjm
Wellllll; in the end I could bring it up to 15#'s of boost and all was good. Over that it would break up and run ****ttty. A/F has been doing fine.
After talking to a bunch of people tonight I think I'm gonna look at it as maybe bad gas and try cleaning the tank and going with fresh.
Originally Posted by Casey02L
Just put it down to 10#'s of KB boost and all is GREAT! Could @ 19#'s it be pegging a SCT MAF???
About to step it up little by little.
On the fuel. I had plenty of FP. The pumps are going into (2) -6an lines out the top of the tank into a big aftermarket filter. SO, I eleminated that issue of the "y" fitting and hose problems.
Casey,
You may have some trouble igniting the mix at 19 lb after you get moving and have come nice cool dense air flowing to the intake.
You may want to decrease your plug gap, I use a boost a spark to avoid the problem.
Originally Posted by svt4me
Casey,
I had IT22's down to .028~.030
I've had to think about it a lot, and it ran great 2 days before in fairly similar weather. Then I pulled it out and drove it, but didn't get on it because it was down to less than 1/4 tank. Filled UP with gas to the top and after that got on it and thats when all hell started happening. So, soon as I get a chance I am draining the tank.
Casey could be the maf or still a coil pack. They react diff to diff loads. WIth only 10lbs of boost the load is smaller. Just a theory. I will call my uncle at astro tomorrow and see if the can test the coil packs for you if you birng them to them. If you want hollar.
Those are the suggestions I am looking for! But, We watched the FP and it was almost up to 60wot and holding steady. Tank was full of fuel too.
I think I'm going to try pulleying down to about 8~10#'s of boost and seeing if it still does it. Then work from there.
Originally Posted by SVTED
$11 fuel filter. Happend to me. If your running race gas change at least twice a year. Especially in spring if it sets for a month or two. ****'s- up the paper in filter. Ed
Plan is to change all the fuel and filter and fresh low gapped plugs. See if anything gets better with that.
Originally Posted by silverzz28
I know exactly what is wrong with it
Sorry everybody; local thing going on. Back to the original topic
Casey, remember to do a bore scope on the cylinders. I found out the hard way about melting a plug. One must always aske them self where the melted material went? My piece of electrode broke free from the top of the piston and wedged it's slef between the piston and the cyl wall. Put a nice key way in the cylinder.
God Bless,
Suavy
God Bless,
Suavy
God Bless,
Suavy
God Bless,
Suavy
At this point I have to hope for the best in that those parts went out the exhaust cleanly. I have not finances or desire to do any motor work right now.
bad fuel happens all the time. might want to detune for the street
who cares if you got 20hp less on the street, cant use it all anyways
