8lb or 10 lb Tuners ..built motor guys
Hello all ,
Getting ready to get a built motor put in the truck will be running stage 3 patriot heads ,stage 2 crower cams my question is with what im looking to do,..Do i need the 8 lb and 10 lb lower pulley.SC is a Kennebell,...Looking to make 600 rwhp on 93 pump.Another Q is how are some of you making this god awful amount of rwtq that im seeing.
Thanks for any feed back Bob
Originally Posted by Don's Bolt
8# lower should do it
Make sure you upgrade your fuel rails, injectors and put a good adjustable fuel pressure regulator on it.
Thanks again Bob
Originally Posted by Whitelighting
THKS 4 the feed back have done the fuel pumps and put in 60 lb injectors,...up grade fuel rails ?where can i get those? love ur truck what kinda timing are you running on ur street tune thats a chit load of rwtq you got there think ive lost some low end tq with the long tubes.
Thanks again Bob
Thanks again Bob
On the street I run a wimpy program, not a ton of timing maybee 12 degrees
I just run 97 f150 fuel rails allong with a adjustable fuel pressure regulator.
Thks Bob
