Updated Nitrous Plate from Racetested
Old Nov 27, 2005 | 06:17 PM
St Louis Lightning's Avatar
There has been a lot of talk about the length of the racetested nozzle. It is prime suspect #1 on why I didn't see the power expected. Denny's first run of plates had a problem because his CNC guy didn't follow specs. Sal modified his plate to give me a bit more clearance and here is what it looked like:
Here is Denny's new plate:
I'm not really sure when I'll have a chance to test this out on the dyno, but we are on the right track.
-Mark
Old Nov 27, 2005 | 06:34 PM
MISTERgadget's Avatar
My original prototype looks like your updated plate.
Old Nov 27, 2005 | 06:35 PM
2000L's Avatar
Looks alot better. Thats approx. how much makes it through on my stock plenum.
Old Nov 27, 2005 | 07:07 PM
Neal's Avatar
HI!... I did the same kinda thing on a old POWERAID spacer. I had the Helix machined out to match my BBK 75MM TB and then drilled and tapped from my NX nitrous nozzle.
Old Nov 27, 2005 | 08:13 PM
Here is a side by side on the two plates I have from Denny. The polished one is the new style. Notice is is a little thicker and the orientation of the hole has changed a bit.
Old Nov 27, 2005 | 08:19 PM
On second thought maybe my original looks like yours?
i'll take a look at them once i get back to gainesville tonight.
Old Nov 28, 2005 | 12:40 AM
tallimeca's Avatar
hmmm
has anyone done a comparison of jets inserted in spacers like this one........vs jets put directly into the plenum???
Old Nov 28, 2005 | 07:20 AM
Rob_02Lightning's Avatar
Very good Mark
Nice to see the Plate back on target
Your new plate is how Sal and I mocked up the Proto Type, as said it was in the final stages that apparantly the problems occured
The Plate actually started out Straight
That wasnt going to work
This is what Sal and I came up with
Old Nov 28, 2005 | 07:24 AM
The final design of the Proto Type
What happen between that and the production mod is unfortunately in the hands of the CNC guy
Glad to see it back on target
Mine dyno'd at 550/655 with a 100 shot using the plate
The only camparison I can provide is 501/615 screwed in the upper using a 75 shot
But the 550/655 was with 4lbs more boost so sorry not to helpful.....
Old Nov 28, 2005 | 07:38 AM
Originally Posted by Rob_02Lightning
Little bit of irony that YOU have that on a DARE box....
-Mark
