wiper cowl mounted nitrous solenoids
Old Nov 23, 2005 | 05:50 PM
halflife's Avatar
I think I figured out how I am going to mount and run my lines so that all my solenoids are in the wiper cowl but would like to see some pics of similar installs of nitrous in the wiper cowl.?
I am basically trying to make everything hidden.
Now I just need to figure out a way to get the jets mounted somewhere so the are not seen.
Advice?
Pics?
Secrets?
Old Nov 23, 2005 | 08:56 PM
LatemodelRacer2's Avatar
i mounted my n20 solenoid under my air box. then covered it in the black stuff ford uses. mounted the fuel solenoid to the back bolt on the supercharger that holds the bracket for the stuff on the drivers side. cover all the lines up with that stuff and noone will see it even if they look. I sharpied my nozzle black and covered it all the way as far up as it would go with wire loom.mount the relay under the black plastic thing on the left side plus theres easy acces to the power there. the psp plate is actually very stealth when done like i did. Or you could always have the bottle mounted behind the seat with a dummy line and bracket in the bed so you can tell people you left the bottle at home but whod do something like that
post your email and ill shoot some pics of mine over.
Old Nov 23, 2005 | 09:24 PM
Sharpshooter's Avatar
m202748@bellsouth.net
Can I get some pictures.
Old Nov 25, 2005 | 04:24 PM
wydopnthrtl's Avatar
I too looked at this method. I *was* going to go through it this winter. But... the whole point of injecting NO2/fuel before the blower is flawed to begin with.
Rich
Old Nov 30, 2005 | 01:56 PM
halflife's Avatar
tomb@pcffund.com
thanks alot!!!
