Bassani Cat Pipe installed.
Old Jan 22, 2000 | 03:04 PM
2fast4u's Avatar
Smile Bassani Cat Pipe installed.
I just gotdon installing my cat pipe. It took about 2 1/2-3 hrs to do. I used jackstands and the install was straight foward.
I do however cut my nuckles. Well of coarse it had to start snowing in the middle of the install. So I have not driven it yet. BUT the sound of it idle is sure nice.
I reved the engine a couple of times and I am once again impressed. If the weather gets better I will keep you posted.
As soon as I get it out of the garage.
Gotta go off to install the superchip.
Vern
99.5 Lightning (black)
Alpine CDA-7941
Diamond Audio M551
MTX Thunderforms
RF 600a4
Borla Cat-Back
Bassani Cat-Pipe
Superchip
Airaid ram air intake on its way
JBA w/ Jet hot coating on its way
PSP Air Filter on order
[This message has been edited by 2fast4u (edited 01-22-2000).]
Old Jan 22, 2000 | 03:59 PM
LightningFreak's Avatar
Post
2fast4u
do you have the headers already in place?
are they bassani headers?I also want to make
sure I understand the bassani system that
I keep on obsessing over. 1. headers
2. cat pipes 3. mufflers,x-pipe and exit
pipes do you intend to install the whole
system. if all goes as planned i'm ordering
mine monday.
Old Jan 22, 2000 | 04:48 PM
2fast4u's Avatar
Lightbulb
LightningFreak
I the stock manifolds for now. I ordered the JBA headers with that they are a little easier to install and cost was also lower. I also have the borla cat-back. I did things all backwards.
I started with the borla and it sounded great. So then I went with the cat-pipe I was looking for performance now and I had to take the borla off to install the cat-pipe. And when I do the headers I will have to take it all off again. I should have done all at the same time.
I did just get back from a test drive. The roads are dry for a little while. I am really impressed with the sound generated now.
The cat-pipe give the louder tone and it sounds great.
I curious what the stock exhaust with the bassani cat-pipe would sounded like.
I read somewhere that the guy from bassani said the most power was generated through the exhaust system. I believe it has to be the cat pipes because there is a small cat on the 90's in the stock system or the headers that is another weekend.
Enough from me for now.
Vern
Alpine CDA-7941
Diamond Audio M551
MTX Thunderforms
RF 600a4
Airaid intake on the way
Bassani Cat-pipe
Borla Cat-Back
JBA headers on the way
Superchip
