need advise on lowering my 2001L
Old Nov 5, 2005 | 12:51 AM
veloci's Avatar
Cool need advise on lowering my 2001L
My L is stock. i would like to do the following:
2" Shackles
JLP traction bars
questions:
if i buy the Hotchkis Bilstein Shocks, will it make the truck handle tighter/more secure.
i do not want to lower the front, only the back. this is why i am thinking about getting the Hotchkis shocks in order to improve handling. I do not want to buy the JLP 3" shackles because i do not think they are worth $100 +.
i want to spend the money i might save in the suspension in order to buy the SCT xcalibrator II , 4 lb pulley and ST/ST brake lines.
what do you guys think?
Old Nov 6, 2005 | 01:39 AM
veloci's Avatar
Cool
ttt
Old Nov 6, 2005 | 02:16 AM
LatemodelRacer2's Avatar
i have 2" shackles and JLP bars on my truck work great even at 600+ hp. I do plan on lowering 4" in the front and 3" more in the back soon.
Old Nov 6, 2005 | 09:31 AM
kromdom's Avatar
From reading around, it is best to buy ALL or NONE of the Hotchkiss (front/rear anti-sway bars, shocks, coils, etc.), maybe why they market it as TVS: total vehicle system because the parts were designed to work best as a whole.
Do not see benefit in getting the rears only plus they are valved differently from the stock L-spec bilsteins....unless you change all 4 at the same time.
The t-bars actually address "wheel hop" (and not traction) and starts to make sense only if you are putting serious hp to the ground.
I say lower your rear using 2 in shackles (level it with the front). Then add your 4-lb pulley, SCT and dyno tune. If you do not have one yet, get an FTVB to perk up your tranny. Good luck
Old Nov 6, 2005 | 09:41 AM
ONELOWF's Avatar
Wheel hop is caused by mis-algnment of the trans tail and pinion gear.
My rear lowering kit furnished axle shims, but they were not enough.
When your done with your suspension mods, take the truck to a driveline shop for realignment.
Cost me $ 80, and cured the problem..... they actually shimmed the trans up 3/4".
LOL
Old Nov 6, 2005 | 10:53 PM
veloci's Avatar
Thank you. i will go with the shackles, front springs and new shock all around. then, 4 lb pulley and SCT tuner.
Old Nov 7, 2005 | 12:33 PM
WHATVPR's Avatar
I have the Hotchkis complete kit, 1.5" front and 2.5" rear and it handles much better and looks much more bad *** than the factory jacked up height in the rear on the 03-04
