Odd Noise
Old Oct 25, 2005 | 09:40 AM
madadd's Avatar
Odd Noise
Hi all,
I know this isnt exactly the easiest thing to answer, but it may just be a common lightning problem so here we go.
When i turn the truck on and select a gear (whilst holding it on either brake) it sounds like something is resonating under the truck. It is quite a loud resonating/rattling noise. It sounds like it is coming from directly under the driver.
Having just fitted new bulbs to the front, I also found out, then when the load on the alternator is increased (all headlamps and fogs on - thus maybe slightly higher revs) it makes the same noise.
Other than that it runs beautifully without any problems.
I hope it is exhaust related. Or a loose something! But have no idea what it could be (as long is it is cheap to fix thats all that counts). my L only has 1800 miles, but it has no warranty with me being in the UK.
Thanks in advance
...Add
Old Oct 25, 2005 | 10:47 AM
typhoon43's Avatar
Cgeck the heatshields right off the exhaust manifolds. They can rattle loose sometimes*
*opinion based on my 97 Explorer. I don't remember if the L's have them as well.
Old Oct 25, 2005 | 01:06 PM
unclemole's Avatar
Can you hear the rattle anywhere other than idle rpm? Did you say that you hear the rattle out of gear when all the lights are on? I have a rattle in gear at idle that I think is the torque converter, 01 with 92k miles. I doubt it's a heat shield as that is more of a high frequency buzz you can hear at a higher rpm.
Old Oct 25, 2005 | 02:23 PM
Coldie's Avatar
Check your flywheel inspection plate. They are often loose and will only rattle when in gear.
Coldie
Old Oct 25, 2005 | 02:43 PM
unclemole's Avatar
Coldie
Thanks, I'll check that.
Old Oct 25, 2005 | 07:14 PM
madadd's Avatar
It sounds like I imagine a heatshielf would sound (Whatever one of those is!) Do lightnings have them?
The sound is what you would expect a thin piece of loose metal resonating to sound like.
It rattles out of gear (more like a buzz than a rattle i spose). It also rattles in gear. However, I only noticed it rattling out of gear when I turned all my lights on. Normally it does not seem to rattle on a normal idle speed.
Never heard the noise at speed. But then again, at speed I dont hear much!
...Add
Old Oct 25, 2005 | 07:16 PM
madadd's Avatar
Coldie
Can that easily be seen by ramming my head under the truck? (out of gear of course )
...Add
