Diesel Powered Lighting??
Old Oct 24, 2005 | 09:24 PM
Scott Dunn's Avatar
This is something Ive been throwing around for some time.
Im needing a tow vehicle for the Red beast and I have my silver truck just sitting there waiting for a new engine.
I have been seriously concidering dropping in a 6liter Diesel powertrain into the silver truck.
I know it sounds nutz but Ive been mulling this idea around for a while now.
Any thoughts???????
Scott
Old Oct 24, 2005 | 09:27 PM
chimshady1's Avatar
Any thoughts???????
Scott
Go for it!!! That would be insane!!!!
Old Oct 24, 2005 | 09:28 PM
svt450r's Avatar
I also was wondering how that would work out the diesels are making some seriouse power it wouid definatly be cool.
Old Oct 24, 2005 | 09:38 PM
Hostile03SVT's Avatar
tha would be absolutely Hostile!!!! go for it!!!!!!!
Old Oct 24, 2005 | 09:46 PM
samiam513's Avatar
you'd def need new brakes bc now ur adding even more wieght.
Old Oct 24, 2005 | 09:48 PM
DEIMATT's Avatar
I think your NUTS!!!
But birds of a feather flock together!! LOL
Can't wait to see it when its DUNN...lol.. I will bring the
Old Oct 24, 2005 | 10:25 PM
Shocked's Avatar
I sent Sal an email about this a couple of months ago, said it could be done. I have a 6.0 L Diesel in my 05 F-250, you can make tons of HP & Torque with those motors, the only problem with the 6.0 L is puking coolant, I believe I heard the head studs are weak.
Old Oct 24, 2005 | 10:38 PM
while you have that beast out put new head studs in.. arent the 6.0 basically the same setup as the 5.4? i know crap about diesels but im almost positive they are.. ill be very interested in seeing how your project will go, and i may have to drive to Sals to see it while its getting done when the time comes.. Sal is da man!!
Old Oct 24, 2005 | 11:14 PM
DynamiteCandy's Avatar
that would be sweet, go for it. you would probably be the first to do it
Old Oct 24, 2005 | 11:26 PM
sonic blue l's Avatar
actually the 6.0l is not even close to a 5.4l gas, well the trans bellhousing bolt pattern is the same, but everything else is different.
6.0l 32v, 2 piece main block, 2 piece oil pan, front and rear engine covers, rear timing gear train, vtg turbo with stock boost around 24 psi, etc, etc.
It sounds great but I bet launching would not be the easiest of tasks with that much weight upfront, plus the front end would have to be cut out or run a differnet intercooler. Custom rad, etc.
Probably cheaper to buy a built 5.4 for a lightning then a 6.0l engine, or sell the other lighting and save up for a 4.5 v-6 diesel f150 - that is if ford ever gets around to putting them in the trucks. Or just buy a superduty with the 6.0l and have two of the best looking trucks that ford makes.
Old Oct 24, 2005 | 11:28 PM
SVT F15O's Avatar
Before I returned my father's old truck(04 F-350) to Ford I noticed it had NO coolant in it, is this why>??? -Mat-
Old Oct 25, 2005 | 12:42 AM
zbornac's Avatar
I would stay away from the 6.0. Just too many problems with them. I see them coming in all the time at a much higher rate than the 7.3. Granted we like to use our trucks a little more than the average person out here, the 6.0 has not been near the setup the 7.3 was. May have something to do with why it is getting replaced......
-Kimball
Old Oct 25, 2005 | 12:45 AM
SILVERLIGHTNING's Avatar
That would be my next vehicle purchase
FF
Old Oct 25, 2005 | 02:58 AM
CoCoCountyLbolt's Avatar
LMAO
Old Oct 25, 2005 | 09:16 AM
Scott Dunn's Avatar
I tossed this out just to see what the feedback would be like. Its something that Ive thought about for sometime.
I need a pulling truck for Red and thought that it would be different to build a diesel Lightning. I will be looking for a doner vehicle either 6.0 or 7.3 just to see what can be done.
