Air/Fuel gauges...which to use?
Old Oct 4, 2005 | 08:39 PM
SVT527's Avatar
I'm planning to install air/fuel gauges in both my 03' Lightning and 00' F-150 4x4(5.4 s/c). I just can't decide which to go with. I have all Autometer gauges in both so I'm kinda leaning w/ them. Can anyone give me pro/cons of different gauges. Any info. is greatly appreciated. Thanks
Old Oct 4, 2005 | 09:02 PM
White01's Avatar
If you get an air/fuel guage, I suggest that you get a wideband set-up. These tell you in real time what the air/fuel is. The ones autometer sells are just a light show. They use narrowband technology. Some of the best guages are, Dynojet wideband, AEM wideband, FJO wideband, ect.
Good luck with your choice,
Rich
Old Oct 4, 2005 | 09:09 PM
SVT527's Avatar
Thanks Rich,
Are all the widebands pretty straight forward as far as install?
Old Oct 4, 2005 | 09:20 PM
White01's Avatar
I have the AEM wideband, it has a digital guage which is what I wanted. It also has an analog output which allows me to datalog to my x-cal 2 along with the other perameters that the x-cal lets me log. As far as ease of installation, this is to simple to install. 3 wires and the sensor. You have the power, ground,analog and the wideband sender in the exhaust.
The dynojet has an analog guage and allows you to datalog RPM,throttle position, air/fuel. I understand it is harder but how much I couldn't tell you. I wish I could comment on the other brands but I can't. Maybe someone else will chime in and comment on the others. You can also use the search here on the forum and look up widebands.
Rich
Old Oct 4, 2005 | 09:57 PM
svtandy's Avatar
I like my dynojet wideband, it also has a datalogging feature so you can go back and check you runs, good way to check to see if the A/F's are right throughout the run. you can also program it. it has a warning LED on it so you can have it trigger to come on under certain settings. for example, mine is set to come on under these conditions: greater than 60% throttle, over 3,000 RPM, and an a/f greater than 12.1 the light turns on. this feature is nice so you don't always have to watch the A/F gauge.
Old Oct 4, 2005 | 10:52 PM
meansvt00's Avatar
dynojet here and it matches the autometer phantom series perfect the guage itself is actually made by autometer
