WideBand commander meeting of the minds.
Old Oct 4, 2005 | 06:31 PM
svtandy's Avatar
okay, I was fiddling with the wideband programming some more and I found while playing with it that it annotates that my throttle is only hitting 90% as a WOT. I checked with the predator and my max voltage for throttle position is hitting 4.57V so that is good. is there something in the setup that I did wrong, i pushed the position on the analog 1 over to 100% should I go with the voltage selection instead?
just trying to play around and figure it out some more.
Old Oct 4, 2005 | 08:29 PM
chesster51's Avatar
If I remember correctly, you have to set your throttle position when you set up the analog inputs. I think it was just a matter of depressing the accelerator to the floor and assigning that position 100%. You can still reset it.
Old Oct 4, 2005 | 09:09 PM
georgia-SVT's Avatar
Yep go to your throttle position analog setting with the truck on BUT not running click on the word TP CLosed it wil set the value then go WOT hold it and click on the word TP Open this will set it up for you.Also make sure your TPS voltage is .99 check this with your digital ohm meter loosen the screws and get it as close to 1v as you can .99max.
jeff
Old Oct 4, 2005 | 09:10 PM
LatemodelRacer2's Avatar
4.57 is WOT on my truck
Old Oct 4, 2005 | 09:45 PM
svtandy's Avatar
yep got it, BTW WOT settings is okay at 4.57, mine is 4.57 also. I called RWTD and asked to get info on this. James said 4.6 is considered WOT. so 4.57 is fine.
Old Oct 4, 2005 | 10:59 PM
meansvt00's Avatar
mine also
