anyone using these shackles...
Old Oct 8, 2005 | 06:55 PM
SVTPIRATES's Avatar
thanks for the info. didn't know that i had to put the truck on the ground. if it didn't say that in the directions i would have definatly F'ed it up. I will drive it around before i measure.
thanks
kurt
Old Oct 8, 2005 | 08:51 PM
evo's Avatar
evo
Originally Posted by bglanden
I saw about a 1.5" drop with them on my 03'. We all know the extra leafs on the 03-04's.(still looked like a 4X4). I finally reached my desired height with fiberglass leaf's and 4" drop shackles, which are on the 3" setting.
You can remove a leaf from the rear spring's (03-04 stock spring's) if necessary to reach the desired height.
Bryan
Same here. I did a before and after measurement on my 03' and got an inch and a half drop.
Old Oct 9, 2005 | 08:00 AM
SVTARKANSAS's Avatar
Originally Posted by MHMCGILL
Check you tape.
With the JLP 3" I got just under 2.5" drop measured before and right after.
Where are you measuring - at the wheel well or at the rear bumper? Three inch shackles should result in about 1-1/2 inches drop at the wheel well and close to 2 to 2-1/2 inches at the rear bumper.
Old Oct 9, 2005 | 04:38 PM
evo's Avatar
evo
I measured center axle (rim) to wheel well.
Old Oct 10, 2005 | 08:23 AM
So am I. I suspect MHMCGILL is measuring at the rear bumper which would be about right. Even with a 3 inch drop shackle you won't get a full 3 inches at the rear bumper because the front suspension is fixed in heigth and acts like a fulcrum. The rear falls about 1-1/2 inches directly over the rear axle, and proportionally the rear bumper is going to drop about another 1/2 to 3/4 inch since it is further out from the front wheel fulcrum.
