Suspension and Brake people in here
Here is my plan for the next month... I am going to order the Stange Enginneering adjustable shocks, 2004 Bilsteins up front, Ground force 1.3" front lowering springs, an 03-04 leaf spring with 2 leafs removed. I already have 2" drop shakles that i will be using in the rear too...
Is there anything I am missing or that I will need to do... I know the Strange shocks are meant are supposed to work with Lowered Lightnings, but will I have to redrill or get shock extenders, or is there anything I should considering doing while I have it up...
I will be adding Rotor Pro dimpled and slotted rotors as well.. What brake pads would you recommend and do I need steel brake lines or would that be a waste of time...
Any suspension or brake suggestions will be welcomed... I would love a TCE brake kit, but no way to afford that so I need to be a little cost effective.
In my opinion removing leafs from the rear is a big mistake. I don't no anything about the ground-force kit. If you can find out the spring rate it will help you determine how the ride will be. Dimpled and slotted rotors in general are a good upgrade. Just make sure they are not plated. If they are plated 9zinc, zinc/yellow, cadmium, etc) find another brand.
Originally Posted by JohnEagle
Why would the coating make a difference on the brakes ?
Originally Posted by 35thPony
Why is removing the spring a big mistake in your opnion? I will never tow and I will need to lower my rear another 1.5" when I lower the front... Are there any other options?
If you want to hold off a few days. I bought a new pair of Strange Engineering shocks and gave them to Wydopnthrtl (engineer) to do some testing. I believe he is going to the track this weekend at Test and Tune.
I know he's added a mod or two since his last appearance, however I'm certain he'll do some tests to account for those variables.
He told me a few preliminary opinions on the shocks, but I'll let him say it.
Hopefully I'll get him to do a back to back test later in October with the stock Bilsteins and then switch over to the strange shocks for a comparison. I could do it, but Wydopnthrtl is a little more experienced at the track and launching then I am. (Haven't been to the track in over a year and I've added substantial mods since the last appearance)
This past weekend I put the strange shocks he gave me on and have only driven about 80 miles so far. I did stop and change them a few times.
So far I fail to see the rebound being any different than the jouce efforts? The instructions say different settings for road coarse and drags. (makes me think it's not a true drag shock)
I'm hitting the track fri with slicks and street tires. Hopefully will know more afterwards.
Rich
So how is the ride on the Strange Shocks so far? Do you have to remove the shocks to make adjustments on them?
Who sells hangers and which are the best?
So far the here are the things I am fairly certain on, unless I get more info to say other wise.
1) 04 Bilsteins on the front (already have them)($0 but paid $60 a long time ago)
2) Ground Force Springs on the fron with 30mm or 1 3/8" drop and bump stops (already have them)($0 but paid $100 a long time ago)
3) 2" drop shackles on the rear ($0) (already installed)
Thing still left to decide:
1) rear shocks
a) 04 bilsteins ($0) (already have, paid $60 a long time ago)
b) Strange Enginneering shocks ($150)
c) QA1's ($250)
2) Rear lowering
a) Remove Leaf ($0)
b) Rear hangers ($?????)
c) Hotchkis Leafs ($?????)
3) Sway Bars
a) no upgrade
b) Hotchkis front and rear ($475)
c) Adjustable rear sway bar ($90)
What else am I missing here and what are your opinions on what I have chosen and what I have left to choose from... I want something similar in stance to a Hotchkis without quite as stiff of a ride?
1) rear shocks
c) QA1's ($250)
2) Rear lowering
a) Remove Leaf ($0)
3) Sway Bars
a) no upgrade
