Painted Calipers
Old Nov 10, 1999 | 02:20 AM
TybeeC5's Avatar
Lightbulb Painted Calipers
Had some time this past weekend and decided to paint the calipers on the Bolt....here are a couple of pics...later....
TybeeC5
99 Red Lightning #1134
95 Blk Lightning #0737
99 Red C5
87 Red C4
tpetrea@worldnet.att.net
Old Nov 10, 1999 | 02:45 AM
PFA's Avatar
PFA
Question
Hey Tybee-
Will this affect any heat disepation from the calipers, or won't it matter? I had thought of doing this myself, but didn't want to cause any problems.
PFA
'99 WHITE LIGHTNIN'
#0873--1 of 866--
RHINO, Soft cover
LoJack
Valentine 1
Mobil 1
Superchip
Water Wetter
Best ET to date-13.54 @101.51MPH--10/29/99
best MPH to date-102.33
'98 Red Lincoln Continental
Old Nov 10, 1999 | 07:27 AM
Yoda's Avatar
Post
what type of paint did you use, also what brand? it looks great
99' Black Bolt
Clear Corner lenses
PSP Filter (on order)
[This message has been edited by Yoda (edited 11-10-1999).]
Old Nov 10, 1999 | 11:11 AM
Zonaman's Avatar
Thumbs up
The brakes look good, similar to the ML55 Benz. The BMW board has liked the kit that Foliotec sells (about $50, special paint, colors, etc. Did you remove the calipers to paint them? If so, please describe the process.
Old Nov 10, 1999 | 11:38 PM
TybeeC5's Avatar
Lightbulb
PFA......nope, no problems with heat dissipation that I'm aware of....I have been painting the calipers on my Vettes for several years now.
Yoda.....actually the paint was a bright red Ford engine spray paint rated I think at 500 degrees...with a high temp clear coat. Both picked up at auto store....Paint is at Tybee Island, this weekend I'll let you know the name brand when I'm back on the island.
Zonaman.....Nope didn't remove the calipers.
1. Two wheels removed at a time and up on jack stands.
2. Clean entire brake assembly with brake cleaner...the cleaner the better...remove all dirt and grease, oil, road scum ect.
3. Tape off around calipers including hoses, caps ect...Take your time and do it right!
4. Mask off wheel well area with newspaper.
5. Cover exterior of truck with old sheets or tarps and mask off with paper around outside of wheel well.
6. Install three or four thin coats allowing time for drying between coats.
7. Top with clear coat for desired look ( I put three coats)
While you waiting between coats is a good time to really clean your wheels and put Zaino polish on them bad boys!
Take you time and you will have a great looking job....If you enter your truck in shows, the judges always love the look of painted calipers. Hope this helps....later
TybeeC5
99 Red C5
87 Red C4
Old Nov 11, 1999 | 02:32 AM
PFA's Avatar
PFA
Cool
Hey Tybee-
Thanks for the info. The calipers do look great! I think that will be my next small project.
PFA
'99 WHITE LIGHTNIN'
#0873--1 of 866--
RHINO, Soft cover
LoJack
Valentine 1
Mobil 1
Superchip
Water Wetter
Old Nov 17, 1999 | 12:25 AM
PFA's Avatar
PFA
Post
Hey Tybee
Did you happen to find out the name of the paint this weekend?
PFA
'99 WHITE LIGHTNIN'
#0873--1 of 866--
RHINO, Soft cover
LoJack
Valentine 1
Mobil 1
Superchip
Water Wetter
Old Nov 17, 1999 | 01:15 PM
MRBBQMAN's Avatar
Wink
Wyldman, we can't be left out because our trucks are already color coordinated. how about a neon lightning bolt on the calipers, that lights when the brakes are applied.
ps: thanks for the smoke covers, arrived today
Old Nov 18, 1999 | 12:55 AM
Wyldman's Avatar
Post
I guess I'm fortunate to have the Black Beast. My calipers are already painted black, so I don't have to mess with it.
Finally, a break!
Chuck 'Wyldman' Shelton
wyldman@houston.rr.com
Black 99.5 Lightning Build # 1273, DOB 5-14-99, NLOC #315
CD Changer; Tow Pkg.; Lojack; Sal's custom nitrous chip; G-Tech/Pro; SnugLid; BedRug; Invinca-Shield, full kit; NOS KIT 80 hp shot (currently); Clear and smoke Lexan fog light covers; 3M Ti Window Tint; Bel radar detector (shouldn't be an accessory); PowerStack cone filter (a.k.a. supercharger waker upper); American Auto Designs ram air hood; Cal-Tracs traction bars
Old Nov 18, 1999 | 10:32 PM
TybeeC5's Avatar
Post
PFA......Stupid me forgot the name brand, but it was a high temp Ford Red spay can that I bought from a auto supply. I used a little over one can. I'll look again this weekend and try to E you the name brand....after adding up the cost of the toys on another thread I'm brain dead....sorry
TybeeC5
99 Red C5
87 Red C4
Old Nov 19, 1999 | 02:12 AM
PFA's Avatar
PFA
Talking
Hey Tybee-
No problem. It looks like most our warm weather is gone anyway. This will probably have to wait until spring. If I went out and looked I could probably find some myself! TIME TIME TIME...
PFA
'99 WHITE LIGHTNIN'
#0873--1 of 866--
RHINO, Soft cover
LoJack
Valentine 1
Mobil 1
Superchip
Water Wetter
Old Nov 19, 1999 | 07:44 AM
Yoda's Avatar
Post
hey I used some stuff called Plasti-kote. Its an engine enamel spray that resists heat up to 500 degrees. It comes in a silver bottle, then I used Dupli-color (co) as the clear coat, again has 500dgr heat range.
99' Black Bolt
Clear Corner lenses
SVT #3443
[This message has been edited by Yoda (edited 11-19-1999).]
Old Nov 19, 1999 | 01:21 PM
PFA's Avatar
PFA
Talking
Thanks Yoda. I'll have to get out there and see what I can find.
PFA
'99 WHITE LIGHTNIN'
#0873--1 of 866--
RHINO, Soft cover
LoJack
Valentine 1
Mobil 1
Superchip
Water Wetter
Old Nov 29, 1999 | 11:40 AM
gearhead's Avatar
Thumbs up
Hi y'all...
Been on the road a bunch lately (35,000 mi. in my big truck since September). Anyway, saw this painted caliper thread and decided to put in my experiences. I have painted my calipers with Rust-oleum Sunrise Red (glossy). Hand brushed it on with excellent results. I have been hand brushing detail parts for a long time. I even use the technique on my engine block in my Fairlane (no overspray to contend with).
Total cost was less than $5.00! Just another way to achieve similar results.
Miss not having a chance to check the sight out as much as I would like....no internet in the semi yet.
