Cam timing? Could it be off?
Sal you beat me to it.... yeah it was hard to tell, Sal checked just about everything and the only thing left was the timing chain. Way to go Ford tech!!!don't trust a dealer ...super job replacing that chain.
On another note, the truck never ran as strong as it did once Sal fixed the problem.
why not pull the cover and check the timing chain?
Good luck with your issue!
Originally Posted by Woodys2000
Call Micheal At L&M Engines 215-675-8485. He sells split crank gears that are adjustable, and they are cheaper. Or you can go to his site. http://www.lmengines.com/ This is this is who AVT Performance uses.
They degreed my buddy's Factory stock car and he reccomends them very highly.
Originally Posted by Casey02L
I find it hard to beleive that they would do that, but if you knew some of what they did/didn't do you might be totally shocked
I hope you get this all sqaured away soon. I know what you are going thru.
Thanks, -Mat-
svt_f150@sbcglobal.net
Originally Posted by SVT F15O
Would you mind sharing>??? That company always brought up my interest and I was thinking of going with them for a Mustang motor later down the line.
Thanks, -Mat-
Thanks, -Mat-
Originally Posted by promodlightning
Suavy, my engine builder and I spent about a full day setting the solid lifter setup on my motor. What a pita, the lifters had to be sent out and machined down 3 times since they were either holding the valve open on the intake then the exhaust. As far as the adjustable crank gears being cheaper, they are a little, but the cam gears are so much easier to set, plus you will have tons more adjustability. Talk to Mike at lmengines, Suavy, Im sure he will give you a deal.
Hey promod, give me a call sent you a couple of e-mails I need to call in a favor.
God Bless,
Suavy
Mat; you get my email?
How are things working out now>??? -Mat-
Originally Posted by lightninquick
hey casey, do you have your problem pin pointed yet?
Casey, sorry for the delay but yes I got your email. Some very interesting and disturbing info.
I took the mis-installed Crower Stg2's out and put some Comp Stg3's in. It's running pretty good; been waiting on a few parts to get it tuned and setup right. It should be good to go in a week or two
Basically they are working out however I take care of them from decisions to money. The builder has left me out in the cold on this one
I am glad you are getting her back up and running though. Goodluck with it and I wish you the best. -Mat-
I know all about being left out in the cold man. I feel for you there. If it wasn't for that my truck would have a roll cage and be a different color right now.
Thanks; been good seeing you get yours going too
Yeah; if I hadn't had all the problems mine would probably be on the bottle now and trying to running mid 6's in the 1/8th. For now I'll see how it'll do on boost alone; hopefully something in the 6's close to 100mph.
Casey, I would love to talk to you about this process can you call me at (586) 752-8167 I'll be there until 2 am daily. Or if you would e-mail me your No. I'll call you?
God Bless,
Suavy
God Bless,
Suavy
I found these guy's here in Michigan that are going to degree and set up my cams for me wish I would have went with them to start with. www.racingengines.com
I actualy went to his shop 2 times before I went with the group I'm with now. As fait will have it he was not available both times I went there.
Just thought I'd share the info
God Bless,
Suavy
God Bless,
Suavy
Originally Posted by Fast Gator
damn Casey
sure hope you get the problem identified and solved. These trucks are alot of fun when everything is right, and a frustrating bitch when problems occur.
Am I the onlyone enjoying a built motor
My JDM built long block is still going strong after 10 months. at this time i can only guess what the problem is. I hope you can get it worked out
