Frame Replacement
Old Sep 9, 2005 | 12:54 PM
MITCHYKINS's Avatar
Frame Replacement
i have a 01 lightning that i have to change the frame (oak tree bite)
have new frame at the powder coaters
looking for detailed cab removal seqence
I saw on one of tim's post a bare frame
mitch
Old Sep 9, 2005 | 12:57 PM
Silver-Bolt's Avatar
I don't have a step by step but it is very easy. Only like 6 bolts that hold the cab on.
Old Sep 9, 2005 | 04:27 PM
chucks bp's Avatar
try this, http://flatratetech.com/images/nav_how_to.htm it will get you in the right direction!
Old Sep 9, 2005 | 04:45 PM
brain bypass's Avatar
nice move on powdercoating. much better than the ford undercoating goo.
Old Sep 9, 2005 | 04:49 PM
MITCHYKINS's Avatar
thks I found that once but couln't find it again when I needed it
mitch
Old Sep 9, 2005 | 04:59 PM
chucks bp's Avatar
That sight will give you the basics you will have to do something with the intercooler plumbing, pump wiring and fuel pump resistor. You may have to check for additional grounds or wires, but most of the truck platforms are the same. I saw that and put it away just for info glad that it may help with you're project.
Old Sep 9, 2005 | 05:28 PM
MITCHYKINS's Avatar
ford under coating crap is giving my powder coater fits
blasted frame then put in oven
goo seaps out of the bracket seams
work on his third go around at blasting it
mitch
