Wide band question.
Old Sep 8, 2005 | 10:46 PM
svt4me's Avatar
Wide band question.
The DJ WBC is now installed and running well. Next step is to control the nitrous with it.
I have a quwstion for you wide band users, after the standard stop light grandprix when I get off the throtle the wide band shows verry lean until the RPM drops to normal. At WOT it runs 11 to 12, at idle and part throtle 14.7 with a little hunting at idle. The lean condition is only after backing off quickley from WOT.
Is this normal?
Old Sep 8, 2005 | 10:56 PM
LatemodelRacer2's Avatar
what nitrous kit are you running? Id like to wire my NX kit in to use my dynojet as a window switch so maybee it wont just roast the tires on the shifts.
Old Sep 8, 2005 | 10:57 PM
SLVRLTNG's Avatar
it's normal, my gauge pegs lean on deceleration...
Old Sep 9, 2005 | 02:17 AM
promodlightning's Avatar
Same here.
Old Sep 12, 2005 | 10:25 PM
svt4me's Avatar
I have a nitrous express set up. I will trigger on TPS, RPM so no throttle switch. I also plan on only alowing a triger if the AF is ok.
I guess I wont worry about the lean deceleration.
Old Sep 12, 2005 | 11:25 PM
JoeLightning's Avatar
It's not really lean. Under those conditions the injectors are shut off - no fuel is entering the engine at all. Just one big air pump..... Joel
Old Sep 13, 2005 | 01:12 AM
i set my nitrous express kit to run off the wide band this weekend. i gtech it and i noticed a conistent 1 tenth loss between it and the WOT switch
Old Sep 13, 2005 | 03:10 PM
Sharpshooter's Avatar
Latemodel,
Did you try turning off the A/F parameter on the WBC?
Old Sep 13, 2005 | 06:56 PM
Originally Posted by Sharpshooter
Latemodel,
yes i had it spraying at 3,000 rpms at WOT. But the reason that didnt help is i run my truck around the streets on slicks so i was nailing it to the floor from a stop and there is the delay in the nitrous and i had a race that night so i just unhooked it from the WBC and did it the regular way
Old Sep 13, 2005 | 07:02 PM
svtandy's Avatar
yes, as they discribed, no lower fuel requirements plus the lesser load on the engine, basically its the engine is coasting at that point.
