Fuel Tank "Y" Fitting revisited
After reading a post by Jody I dropped my fuel tank this past weekend and found this. If you have been batteling burnt plugs or fuel realted issues at WOT it may be a good weekend job.
God Bless,
Suavy
God Bless,
Suavy
Hey Suavy ,hows it been? Thank God you found that before it caused a lean out on the motor. We all know you've had enough problems already. What made you look there and just curios how many miles you have on the truck?
yes, didn't see the original post on this, what year of trucks does this problem effect, what causes it and what is the fix? just wanna keep this in mind for myself since I might be changing out the in tank pumps to 255's.
I have 120K on my truck and have had the pumps out 2 times since I put the big pumps in back in 2002. Jody made a post about this up graded Y fitting and I read the full post. Last year this time I blew a head on the dyno going WOT I thought it was tune related. Thank God I have not went WOT with my new motor. The truck has been basicly sitting since I got the new motor in. It is set to be tunned on 9/12/05 by Alternative Racing.
Peace,
Suavy
found the original post here for those who have not read:
https://www.f150online.com/forums/sh...d.php?t=209950
good info for those going into the tank, definately will pick up the stainless y when I install the new pumps.
The other thing is kinda disconcerting, the fuel pressure jumping/hunting with the upgraded 255 twin pumps , is that common with all the 255 pump kits sold? if not which ones, if any do not have this problem?
A lot of guys have tuning issues with the a/f jumping around at idle/cruise yet very few of us monitor fuel pressure, we just assume it's right. I'm thinking between these 255 pumps maybe not liking the reduced voltage these trucks use at idle/cruise and those plastic "Y"'s in the tank breaking, getting crushed by the clamps, or whatever that a lot of tuning issues aren't tuning issues at all, but mechanical issues with the fuel pressure not being where it's supposed to be.
Jody
Jody
well, when I finally get around to purchasing the pumps, and when I pull the old ones out, I will definately ohm out the resistance of both the new pumps and the old pumps and will post the results, I will also run a fuel pressure gauge to verify fuel pressure. thanks for the heads up. I will definately ask questions when I purchase this kit also.
also which kit did you purchase and who from? I think this is important and should be published to let people know about possible impedance mismatches from stock pumps and different kits.
Peace,
Suavy
Originally Posted by Suavy
I ordered the Moroso kit it had 1/2" ports and I used 3/8" gas hose the Y block cost 38. and the hose was about 10 bucks.
Peace,
Suavy
Peace,
Suavy
Originally Posted by Whitelighting
Suavy can you post a pic of what you bought getting ready in the next couple of weeks to get my new built motor put in ,thinking i might need to do this....I have a fuel pressure guage on I have the 255 fuel pumps 60 lb injectors a idle it reads 36-38 the more i lean on it the higher it goes....The oil pressure freaks me out all the time riding down the road stays around 55-75 at idle drops sometimes to 25 grrrrrrrr,...any ways if you can show me in detail would be great thanks ....Bob
I was freaking also cuz at idle I would se any ware from 18 to 25 psig. However, the pressure would build as I gave it gas. At 3/4 peddle it would have 80 psig. The pressure gage acts like a tach almost goes up and down with the gas peddle. I can see if I can get a pic of the Y block. I went to true value auto parts and told them what I wanted and they ordered it in. Had it the next day. I also bought 3 hose barbs that were 1/2" NPt to 3/8" hose fitting. Then 3/8" gas hose.
God Bless,
Suavy
