stainless Y connector for in-tank fuel pumps
Old Sep 1, 2005 | 03:12 PM
  #31
camcojb's Avatar
Originally Posted by JeffsLightning
Are you using the C1258 regulator? ($125.95)
No part number on it. It was for a 97 Vette, that's all the receipt says.
Jody
Old Sep 4, 2005 | 10:22 PM
  #32
Casey02L's Avatar
Originally Posted by camcojb
I bumped mine to 33 with vacuum. I got it from http://www.exoticmuscle.com/webpage....MENU=PRICELIST
You need one for a 97-98 Corvette LS1; the later cars did not have return fuel back to the tank and the regulator won't work. I've heard of these selling on Ebay for less, but I just grabbed the first one I found in stock.
Jody
Just curious since the FP could vary depending on how much vacuum your motor is making. What is yours reading when the vacuum line off?
Old Jan 19, 2011 | 12:32 AM
  #33
roger28's Avatar
Erratic Fuel pressure
My base is 33 psi. Without the regulator it wandered between 22-28 psi constantly. I never tried another resistor; I remember Sal mentioning that but only when using aftermarket rails. That would bump the fuel pressure, but my pressure wouldn't even stay low and steady, it was all over the place. Like the computer couldn't keep the voltage at 7 volts or whatever it is supposed to be.
Jody
Having problems with my pressure also .Have the Walbro 255's and cant keep the pressure steady.Would this fluctuation also cause my truck to run rich at idle??Its rich at idle and lean out under load and I'm sure its not a vacuum leak or bad regulator or o2's or resistor,or pumps.Under load it bounce from 20 to 40 psi???Heres a link.My main concern is would this cause it to run rich??
http://www.youtube.com/watch?v=tFi2HMuCAoE
Old Jan 19, 2011 | 12:35 PM
  #34
Veteran: Army
thanks for a bump on an old thread, please give us some info on your truckand it's mod list so we can help you better
Old Jan 20, 2011 | 12:06 AM
  #35
roger28's Avatar
Has 2.3 KB, Boost a pump,NGK TR6 plugs,stage ll cams,15 psi boost,Trick Flow heads,60 pd injectors SB TB,JLP air box it started this right after KB install.Replaced injectors,fuel damper,o2s,pumps,bypassed ballast resistor,checked voltage at pumps which was steady 8 volts,checked IAT which seemed to be working correctly by my digital meter,removed supercharger belt ,no change,performed leak down on all cylinders and it was good,vacuum is between 12 and 13 but idle fluctuates and vacuum isn't erratic,shot propane all around engine with no change on the wide band or idle.Shot propane in the small 1/8 (red) vacuum port on top of supercharger and motor stumbled badly so o2's are doing their job and there doesn't seem to be any vacuum leaks.System holds pressure for at least a half an hour or more after (38psi) engine is off.New fuel filer too.And at idle the pressure stay at about 36 psi steady with just a slight tick but under a load its 20 40 psi back and forth!Going to try the 97 Corvette adjustable reguator.
Old Jan 20, 2011 | 02:18 AM
  #36
Veteran: Army
is there a stainless steel y and submersible fuel line in the tank??
