stainless Y connector for in-tank fuel pumps
Old Aug 31, 2005 | 01:42 AM
camcojb's Avatar
Originally Posted by Suavy
Jody, my truck doesn't lean out at WOT when I let off the gas and it goes to coast it feels like I'm pulling a trailor. Thats why I think that I have a smashed or cracked "Y" cuz on the low pressure side the fuel starts to by pass through the crack. At 1/2 throttle no pinging or burnt plugs feels strong it's the low pressure I'm fightning.
Peace,
Suavy
Mine didn't lean out at wot (thanks to the alcohol injection) but it had a wicked lean surge at higher load/lower rpms like climbing a hill or passing a car in overdrive fairly fast without downshifting. Then once I fixed the "Y" I found that the low speed pressure was moving from 22-28 psi constantly, not stable like it should be. I think there's an issue with the aftermarket pumps and the resistance in the aftermarket pumps or something similar. An adjustable regulator fixed it and allowed me to set the low end a bit higher, about 33 psi and no movement in pressure.
Jody
Old Aug 31, 2005 | 09:05 AM
Casey02L's Avatar
Jody
So what did you end up setting the base FP to that's working for you? Mines been so screwed up I've had it around 50 trying to make it run right.
Also, have you or did you ever try wiring a second resistor in parrellel to up the voltage to the pumps?
Old Aug 31, 2005 | 09:47 AM
camcojb's Avatar
My base is 33 psi. Without the regulator it wandered between 22-28 psi constantly. I never tried another resistor; I remember Sal mentioning that but only when using aftermarket rails. That would bump the fuel pressure, but my pressure wouldn't even stay low and steady, it was all over the place. Like the computer couldn't keep the voltage at 7 volts or whatever it is supposed to be.
Jody
Old Aug 31, 2005 | 12:28 PM
Casey02L's Avatar
Jody
33 with the vacuum line off or on?
Old Aug 31, 2005 | 09:31 PM
Suavy's Avatar
What he said
Jody, where did you buy your regulator from and is it one that mounts in the place of the old vacuum line type?
God Bless,
Suavy
Old Aug 31, 2005 | 09:36 PM
camcojb's Avatar
I bumped mine to 33 with vacuum. I got it from http://www.exoticmuscle.com/webpage....MENU=PRICELIST
You need one for a 97-98 Corvette LS1; the later cars did not have return fuel back to the tank and the regulator won't work. I've heard of these selling on Ebay for less, but I just grabbed the first one I found in stock.
Jody
Old Aug 31, 2005 | 09:57 PM
Suavy's Avatar
Jody
jody does it mount where the stocker goes on our fuel rails?
Old Aug 31, 2005 | 10:07 PM
camcojb's Avatar
Suavy,
It's a direct replacement for ours. They are held in place by a single c-clip; remove this and pull the stock one out. Then install the new one and re-install the c-clip. Don't actually have to remove the rails or anything at all to get to it.
Jody
Old Aug 31, 2005 | 11:58 PM
Casey02L's Avatar
Here's what my "Y" fitting looked like when I removed it:
Old Sep 1, 2005 | 12:05 AM
Suavy's Avatar
Thank's Jody U d Man!
I would have never thought to use a Corvett part on a lightning.
God Bless,
Suavy
Old Sep 1, 2005 | 09:18 AM
brain bypass's Avatar
suavy, i bought mine on ebay for $60
Old Sep 1, 2005 | 10:44 AM
JeffsLightning's Avatar
You don't happen to have a link do you?
Old Sep 1, 2005 | 11:29 AM
well, i just poked around on ebay, looks like there aren't any for sale at the moment. just look for a regulator for a 97-98 corvette. i know hypertech makes one that sells for $119 retail.
Old Sep 1, 2005 | 12:19 PM
camcojb's Avatar
Hypertech told me they had discontinued theirs which is why I went with http://www.exoticmuscle.com/webpage....MENU=PRICELIST
Jody
Old Sep 1, 2005 | 01:18 PM
Jody
Are you using the C1258 regulator? ($125.95)
