Patriot stage 3 users
Old Aug 28, 2005 | 08:58 PM
Spanky99L's Avatar
to those of you using patriot stage 3's what cams are you using? If you are running the crower stage 3's what springs are you running with the stage 3 cam?
Thanks in advance
Will
Old Aug 30, 2005 | 11:48 PM
Spanky99L's Avatar
nobody???
Will
Old Aug 31, 2005 | 12:30 AM
LightninMike's Avatar
sorry dude, using stage II's here
Old Aug 31, 2005 | 02:52 AM
Whitelighting's Avatar
Im going with the stage 2 also to many tune issues with the stage 3 what my searchs have came up with also what i have seen and read only 10-15 more hp to be had with with the stage 3 and thats on the top end,.....just my thought really dont think that is enough power for the problems with the tune lol Later Bob
Old Sep 1, 2005 | 12:38 AM
Spanky99L's Avatar
i found my answer
Crowers spring is 74 lbs@ 1.720"
patriots spring is 75 lbs@ 1.720"
Crowers spring is 245 lbs@ 1.100"
Patriots spring is 247 lbs @ 1.100"
Crowers coil bind is 1.040"
Patriots coil bind is 1.050"
The stage 3 cam is a .612" lift, that means that from the install height of 1.720" the spring's open height will be 1.108" which will leave .068" before their spring coil binds with the crowers. Patriots spring would be open .058" before coil bind.
.050" is considered a safe barrier between lift and coil bind.
Will
