Spindles vs. Control Arms
Old Aug 27, 2005 | 09:14 PM
18throttle's Avatar
If there were no installation issues with the beltech spindles--- i know that is a lot to ask--- but, which is a better way to lower the truck between the spindles and lower A-arms. As far a ride quality, handling, turning, bump-steer, ect... Thanks
Old Aug 29, 2005 | 10:10 AM
SILVER2000SVT's Avatar
Somebody posted on here just a week or two ago about still having bump steer with the drop a-arms.
Old Aug 29, 2005 | 10:24 AM
Tim Skelton's Avatar
Bump steer is a function of the relationship between the tie rods and the control arms. Lowering by any method other than dropped spindles will increase bump steer. Do a search for "bump steer."
Since neither control arms nor spindles affect anything but ride height, the "ride quality" will remain essentially stock.
Old Aug 29, 2005 | 11:03 PM
18throttle's Avatar
thanks for the reply guys. The reason I ask is that I have the western chassis lower arms and their springs, and I have had them for a couple of years. I am happy with them other than a loss in steering radius, and the fact that the sway bar endlinks do not line up. I replace the bushings on the endlinks about every six months or so. When i first learned that the beltech spindles were available I ordered a set right away and I have yet to install them. After seeing the installation problems with the spindles that others are having, I am hesitant to install them. Would you replace a perfectly good set of lower a-arms with these spindles if you had them or send them back. thanks for the help, Bill
2002 lightning
wc a-arms, springs
bilstein/hotchkis shocks
hotchkis sway bars
shackles/hangers
295/40/20'' tires.
Old Aug 30, 2005 | 08:21 AM
billetman's Avatar
I recently had the Belltech spindles installed and I'm very happy with them. The only negative that I've found is the slightly smaller turning radius. I can live with that. The truck rides great and handles much better than stock. Also did Eibach hangers and shackles.[IMG] http://www.mustangmods.com/data/17624/b1.jpg [/IMG]
Old Aug 30, 2005 | 08:31 AM
halflife's Avatar
do you have a pick of the hangers installed?
Old Aug 30, 2005 | 09:20 AM
TampaBlack99's Avatar
He's got 20's.
