Uh Oh!! Huge Problem!!
Old Aug 22, 2005 | 08:26 PM
LatemodelRacer2's Avatar
I have used a wrech before. Just put it on and then slowly turn the motor while holding it untill it has pressure on it.
Old Aug 22, 2005 | 09:47 PM
meansvt00's Avatar
turn the motor back the other way to straighten the strap then take it off
Victor
Old Aug 23, 2005 | 06:40 AM
Rob_02Lightning's Avatar
I am so glad I did mine when the truck was only a few weeks old,
it was still a bitch, but not like some of these horror stories.
Hope you got it off by now Bro
Old Aug 23, 2005 | 12:58 PM
OD1010's Avatar
first of all thank you for everyones input. I did finally get the bracket off and I straightened it out in my viceand then I put it back on the torque converter, the other way, and the stock pulley came off the first try!! At that point i had run out of daylight so i called it quits for the night. I am now in the middle of putting everythign back together. the new JDM 6lber is on but those two tranny lines are rubbing right against the pulley and I already put the bracket back on. They just keep slipping out and hitting the pulley. is there anything else I can do to hold them back?? thanks again.....
Old Aug 23, 2005 | 01:13 PM
OD1010's Avatar
Old Aug 23, 2005 | 01:52 PM
tallimeca's Avatar
yeah
take them out of the bracket and put them under neath it. You may have to tweek the bracket. Then wire tie them in place.
Old Aug 23, 2005 | 03:26 PM
georgia-SVT's Avatar
I just grabbed the line and carefully bent them down out of the way not a big deal.Just grab both lines at the braket and bend it till it clears.Your going to love that 6#er I accually drive the truck eaiser since I put it on no need to re it to red line everytime.
jeff
Old Aug 23, 2005 | 08:07 PM
SVT_KY's Avatar
Duplicate advice ... Sorry
Old Aug 23, 2005 | 08:21 PM
Great news OD, woo hoo.....
jeff
EXCACTLY
No biggy at all, takes all of 5 sec's
I have a 9-7/8" Lower and it don't rub
Old Aug 24, 2005 | 12:00 AM
OD1010's Avatar
Thank you to everyone for your help over the past 2 days. a project that should have taken a couple hours max, turned into a multi-day ordeal. Although my luck did not change much after I finished. As soon as I was done I went for my litte joy ride around the block. My boost gauge was pinned!!! WOOOHOOO!!!!! But then I came around the corner and thewas the police sitting right there. My radar detector went off like crazy so I jammed on the brakes and almost started fish tailing but he still got me for 39 in a 25. Although not all bad luck because I did talk him out of the ticket and got by with a warning!! So anway everything turned out ok and the 6lber is AWESOME!!!! Thanks again for everyones help!!
