mono leaf??
Old Aug 17, 2005 | 09:48 AM
SRTthis's Avatar
mono leaf??
like the title states.... is any one in here running a mono-leaf set up? im not talking about the fiberglass ones that JLP sells but removing the stocK leafs? i dont haul anything other then tires and maybe a few generators but thats about it. nothing to heavy so im not to worried about the towing ... any suggestions?
Old Aug 17, 2005 | 05:56 PM
Eds 01 Lightnin's Avatar
Several months ago we removed a leaf from my friend/neighbors (Scott Russell, the past superbike champion) 99 L and it lowered the rear another inch. We removed the complete hitch assy at the same time. He has no objections to the ride and likes the results. I've been thinking about maybe doing the same thing to my 01 instead of changing out the hangers as I had planned on doing this winter....I never tow with mine either. How many others, aside from 03/04, have removed a leaf?
Old Aug 17, 2005 | 06:06 PM
Silver-Bolt's Avatar
If I remember correctly the Hotchkis are a two leaf setup. I don't know of a single other than the glass ones. Better have traction bars installed if you plan to launch it hard. When I remove my stock springs after making a few passes with no T-bars they were bent bad. Nice twist in the direction the axle rotates. I can't imagine removing leafs from the stock stack. Yes it will lower it. Yes it will ride smoother (softer spring rate) but it will also be weaker. After seeing the stock spring bent like I did I would not consider removing a leaf.
Old Aug 17, 2005 | 06:40 PM
RED 92's Avatar
Ditto...... removing a leaf is dangerous if you drive aggressively.
Old Aug 19, 2005 | 12:49 PM
SRTthis's Avatar
yea im running the metco upper link traction bars along with 2 inc drop shackels. what to do what to do...
Old Aug 19, 2005 | 03:08 PM
Krix330cic(NJ)'s Avatar
Why not just get Hotchkis 2.5" replacement leaf setup then??
Old Aug 19, 2005 | 03:45 PM
SRTthis's Avatar
not looking to do this to lower it but more just let the back squat more
Old Aug 19, 2005 | 05:29 PM
brain bypass's Avatar
what rear shocks are you running?
