Another Nitrous question.
Where does everyone feel is the best place to install the nozzle>???
Right into the intake boot like NX says or into the upper plenum>???
The bottom of the intake boot would be the most stealth so if I am ok there that is probably where it will go. Thanks, -Mat-
Mat
[EDIT]
I've read many many times the BEST location is behind the Throttle Body,
4-6" to be exact. That is not always possible of course, but being behind the TB is important. You do not want to spray through it (if possible). The PSP Plate is the best way to do it IMO,
and will of course put you closest to optimal location.
OR
Do as I do and just grab the dam drill and go for it
[EDIT]
OR
ok ok calm down (you all knew what I meant)
the best place is AFTER the MF TB OK
Meaning you DO NOT want to spray THROUGH the TB, you want to Spray AFTER it.
Sometimes the front means the Back you know,
Take Gator for instance, he got Zactly
His Face Looks Zactly like my ***
-Mat-
