FRPP / Ground Force opinions
Old Aug 17, 2005 | 04:54 AM
Big Shooter's Avatar
i looked around a little, but i was wondering if there is any issues i should know about before ordering this. will i need to take it and have it re-aligned? i kept reading that its a 1-2" drop but Ford says 1.18" all around. is that what the second hole is for? opinons?
Old Aug 17, 2005 | 05:29 AM
Fast Gator's Avatar
Can't help you with the question, BUT ............
if you lived closer, I could set you up with a Ford Racing/Ground Force front springs for a great price. Less than a couple hundred miles on them.
Not shipping them, but if someone was closer to me
(The only reason Iam selling them. is the question of weight transfer)
Old Aug 17, 2005 | 09:16 AM
wydopnthrtl's Avatar
I have the 1" 3" drop by them. Only thing I would suggest is that you shorten the rear sway bar end links by about 2" when using the 3" shackle.
Rich
Old Aug 17, 2005 | 09:24 AM
meansvt00's Avatar
you are better off have the truck re-aligned when ever you change something. its cheap than chewing uo those front tires. as for the back drop yes the shackles are adjustable with the two holes i think the one hole is 1 inch and the othe is 2 inches.
Victor
Old Aug 19, 2005 | 08:32 PM
do they have any problems with spring sag over time?
Old Aug 19, 2005 | 11:08 PM
Shorty's Avatar
Not mine. I've hade the FRPP on for about 3-4 years with no measurable sag.
Old Aug 20, 2005 | 12:31 AM
JeffsLightning's Avatar
No sag here...
Old Aug 20, 2005 | 03:08 AM
im not the greatest at workin on trucks. how hard is this kit to install, and how long does it take?
Old Aug 20, 2005 | 09:20 AM
Shorty's Avatar
On a scale of 1 to 10 it would be a 5. I would set a side most of the day if you were going to do it yourself and have no experience. Recommend getting a friend with some knowledge to lend a hand. Or at least watch and feed beers. There is a lot of information on the subject and do it yourself tips if you run a search.
