KB install.....Help I need pics ...
Old Aug 12, 2005 | 04:08 PM
BRUCEWRS's Avatar
I removed the old blower.Someone told me I have to grind down some brakets?Should i do that first before installing the KB?What do I have to grind down?Does anyone have pics?Thanks
Old Aug 12, 2005 | 05:42 PM
mike00L's Avatar
both of the brackets on either side of your kb have to be ground down since the kb is much wider than your stock blower. the passenger side you can do while its on the motor with a hand held grinder but the drivers side you would have to remove because the grind is extensive and just easier to do with a grinding wheel off of the motor. just dont forget to cover up the intake on top of the kb so you dont get any metal shavings in the blower! that would be bad
