innercooler fluid not flowing
Old Aug 9, 2005 | 10:36 PM
wizechef's Avatar
i think my innercooler fluid isnt flowing. it doesnt swirl around in the res. like it use to. could this be the pump or anything else?!? how do i check this??
any advice is greatly appreciated
thanx
shimon
Old Aug 9, 2005 | 11:31 PM
LatemodelRacer2's Avatar
How many miles are on your truck it could be the pump but then it could be the relay or fuse. Get the manual out and check your underhood fuse and relay.
Old Aug 9, 2005 | 11:53 PM
wizechef's Avatar
its got 80k
Old Aug 10, 2005 | 12:00 AM
L.V's Avatar
L.V
Most common problem is a bad connection at the motor.
Check for corrosion or loose pins.
Vince
Old Aug 10, 2005 | 09:29 AM
brain bypass's Avatar
you may have to remove the pump and clean it if it is not the relay.
Old Aug 10, 2005 | 10:44 AM
Grimace's Avatar
^ what they said. Take the plug off and see if the pins are corroded, or if a wire rotted through. Then, you can start the truck and after a few seconds the pump relay should fire, and you will get 12 volts to the motor. Also, check for a good ground. Sometimes the grounds get corroded between the terminal and the ground point.
Old Aug 10, 2005 | 11:12 AM
wizechef's Avatar
thanx guys. i took out the connection and it looked fine. i knocked on the pump a couple of times... and it started working?!
oh well thank you for you help!
you guys are great!
Old Aug 10, 2005 | 01:11 PM
2000L's Avatar
It would probably be in your best intrest to go ahead and replace it. That is the same thing mine was doing just before it quit. Im sure its probably not flowing the proper GPM. These pumps are only made to operate for so long, failure is inevitable.
Eric
Old Aug 10, 2005 | 01:29 PM
SILVER2000SVT's Avatar
Make sure it's not too full. If it's past the full mark you won't see the swirl as much.
